Rear Beam Mini
  • Rear Beam Mini
    Hi , I have a mini Midas .The actual custom rear beam is in bad condition so I think to use a "sport" mini rear beam so you can regulate the camber and toe in/out .As the track wheel base of the Mini and the Midas is not the same , I know that I have to do some modifications.
    My question is now which( manufactor) mini rear beam are considered as "good" in your opinion , please note it should be in steel
    The only one I could find is the one from Huddersfield, all the other ones are discontinued or very expensive or not in steel.
    Dennis
      I have an early TDK beam with some adjustment but I believe the later ones are fully adjustable..http://home.freeuk.net/tdkracing/FRA.htm
        I think these are made of steel. https://www.superfastminis.com/store...r-subframe-kit
        It looks like it wouldn't be too terribly difficult to narrow if you needed to, or they might even build it to suit your needs if you ask them.
          Thanks to all for the info !
          Yes the beam of superfastmini looks really good , but expensif ....I have also to pay shipping and importtax etc....so finally it would cost me +- 1900$ !!!!!
          But the beam of TDK looks also good and not so expensif , I have asked this afternoon some info ......
          Also the beam of Forgeracing is not bad , I have asked info some days ago .....but no answer yet ???http://www.force-racing.co.uk/produc...beam-assembly/
          A good point is that the beams of TDK and Forge Racing are easy to modify ..if necessary of course.
            Don't Watsons do a rear beam too?
            It'll be wider than a Mini one, but if you're going to modify it anyway ...
              Yes Watson makes also rear beams for mini but they have Golf disc brakes .http://www.watsonsrally.co.uk/html/kits_list_6.html
                what's wrong with the I made for you?
                Have you not painted and go rusty?
                  Atchi , I have 3 Midas cars
                    Oh, so the one I made working OK?
                      Maybe , I think I will install the beam end of the ear , I try first to start up the engine
                        I have just got news from TDK .....they don't sell rear beams for mini anymore .
                          Any use? https://www.ebay.co.uk/itm/Classic-R...wAAOSwZYFflZQO
                          On Ebay now. Not mine
                            Hi Birdman, thanks for the info !
                            But I see is made of alu ........and I prefer steel .... if there's something wrong I can weld it by myself .
