Morning everyone, Hopefully someone can help... I'm at the last stage of a 1.8 k series swap, out of a mgf 143. Unfortunately I can't get it to start. I have researched and used the wiring sticky, also Gazwad has sent over the photos and I have been looking at wiring diagrams.
I have no spark, sometimes it does spark but the moment you turn the key back to position 2 it won't spark again.
As it's an Mgf I have looked through the wiring diagrams etc, and connected the corrosponding wires to the ecu from the 5as:
B/W -TO ECU plug B/W wire
Y/R -TO ECU plug Y/R wire
B-To Earth
Y-Ariel?
Purple to Permanent Live
White to Switched Live
Clicked the key 4 times when connecting battery.
5as responds.
First question, do I need the mems relay?
I am currently using the mini loom for starter and my own fuel pump. There for its not connected, is this causing me problems?
I am using the mini key barrel, loom etc. I have wired in the k series loom seperate, and connected the lives to the starter, then put a fused live to ecu and 5as, switched live to ecu and 5as.
The 5as is in the mini, the ecu is in the engine bay, do they need to be together?
Hopefully someone's picks up on something I have missed.
Many thanks
B-To Earth
Y-Ariel?
5as responds.
Many thanks
