PG1 5th Gears
  • PG1 5th Gears
    Evening guys,
    Looking for some advice and to see if anyone has tried what I'm thinking 😅 I'm wanting to drop the cruising rpm on my pickup project, I'm currently on C Ratio gears with a 3.6 U-Spec f.d. and 70mph is approx 3.5k rpm. Reading Gary's thread the W-Spec 0.714 ratio 5th seems good as it drops down approx 300rpm, but I was wondering if anyone has used a S-Spec 5th with a ratio of 0.649? This is quite a big drop of 70mpg to 3k rpm and I'm wondering if it would be too much of a gap between 4th/5th? Been ages since I've driven a mini so dont really remember!
    I tried the s spec 5th and found it way too tall, killed performance and the gap from 4th was massive. Making the engine quieter makes it feel much more relaxed so I would suggest trying this first (standard rover engine mounts, quieter exhaust, enclosed airbox, tecsound soundproofing etc)
      Cheers Gary, thats what I was thinking as it seems like a big drop! Saves me stripping the box again, but I’ll see if I can get a W ratio one as that sounds better. Will look at making it a nicer place to be with decent sound proofing and such
        Depending what you want to achieve I have all parts here.
        The 0.714 that Gaz has is from a W ratio gearbox. I would suggest this is the biggest jump from the 1.033 4th. As Gaz says, the 0.649 from the diesel box is too tall from the C 4th.
        So, if I was you either swap to the 0.714 5th, or swap gears 3, 4 and 5 from the S ratio set to give a lower cruising rpm but have equal spaced gears.
        Andrew.
          Thanks Andrew! Have you got a U-spec 0.714 W ratio 5th gear? I’d like to keep the C ratio gears I think
            I do mate.
            Like hens teeth and this is my last one.
            £25 posted the pair of gears.
