starter motor not fitting
  • starter motor not fitting
    had to replace my starter motor went onto europarts and this is suppose to fit b18c3 civic aerodeck
    https://www.eurocarparts.com/p/remy-...otor-402600511
    anyone tryed one of these as ive brought one and wont even fit seems to hit on the inside
    This is a pic of my original starter
    Think Twice Before Passing This Mini.....It Could Make U Look F**k**g Silly.....
    my beast
    That is a different design, your one looks the same as the one fitted to my B16A2
      Not sure if Andy is still about (haven't used him in years) but give integrastella a call
      https://www.integrastella.co.uk/stor...ywords=starter
        Unfortunately as some rover and hondas share the same starter you can't rely on ECP to get it right
        First up your picture is the same as my one, mine is from a b16a2 like pomps above and it fit my old b18c6 block and is what I use now on my b20 (can't use the b20 starter as flywheel is different)
        Obviously the one you bought from ECP has a "shield" around the teeth, yours doesn't so it won't fit, the later type vtec ones have the shield, there are some that have different number of teeth as the flywheel is different on I think the really early ones, the auto and manual ones are all interchangeable for the same given model, the sohc and dohc are different and I'm sure you can't swap the earlier cable clutch type either
        Just find one that is the "open" type around the teeth for any integra dc2 or earlier vtecs (b16a2 b18c6 etc) or del sol vtecs and it'll bolt right on, I'd take that back to ECP and go to a honda breakers (or specialist) with your one if unsure, secondhand is fine, no need for a new jobbie
          ok took my original starter to a place local to me who repair starter motors and alternators..the guy tested mine and said yep its a little bit labored..so left it with him...
          anyway he stripped it down to check it out .....phoned me after a couple of hrs and said he couldn't find anything wrong with it🤔 so im stumped....as to why it will only turn the engine very slowly and will flatted a brand new battery with in 3 seconds(the battery is off my BMW diesel
          my beast
            This points to another problem tbh, like something binding (partially seized engine / gearbox /clutch...?)
              thnx for the link kam spoke to andy and hes sending me one out mon/tue
              my beast
                all been check and everything seems to be free
                my beast
                  If the engine turns over ok with the plugs out then your only left with the battery, it might be a new battery but was it pulled out of your beemer or brand new unused battery meant for the beemer, either way did you check the volts, I do as you never know how long it’s been sitting around, has your beemer been sitting around for a while as well?
                  Check your main battery cable to the starter incase its burnt/stripped away in places, I’m not sure how this would drain a battery that quick but you need to give it a good going over
                  I’m still suspecting battery, an engine can drain volts after continuous cranking but not to the point of flattening it, one or two volts from the newish 12v yes but not drain completely
                    tried my battery out of my beemer which is my every day and also brought a brand new battery for the mini...and both drained within seconds
                    recharged the new battery which i brought for the mini left it sitting for a couple of days after charging...put that in the beemer turned the key turned the engine over fine
                    then put it back on the mini and still the same again flat within seconds...should have my replacement starter mon/tue hopefully from Andy so will update whats what
                    my beast
                      As Kam says, check your Battery live is not shorting out, I had something similar years ago when I fitted an LCB to a Mini and it touched the main battery cable, melted the insulation and shorted it out.
                        Finally she runs
                        https://m.facebook.com/story.php?sto...&id=1075991175
                        my beast
                          To me, that sounded really slow while cranking before the startup. What compression are you running?
                          It only took me 3 years to reach 100 posts and become a senior member!
                            standard engine as far as i know doesn't look like its been messed with
                            my beast
