Question about tachometer
  • Question about tachometer
    Hi
    is It possible adjust the signal from the distribuitor yo use with another tachometer, for example engine honda CRX d16a9 with standard 3 gauge from mini
    I have the same engine set-up with a Triumph tach. Works straight from the signal out of the distributor.
      so i dont know what answer...
      im using 3 magnolia speedo for classic mini (what uses mpi mini), and i connect to the tachometer the blue wire from distributor and 12v to the other faston..
        yeah, Blue wire from distributor to tacho.
        Maybe the MPI clock is different to a traditional distributor type one.
          i find this
          http://www.theminiforum.co.uk/forums.../#entry2211317
          i dont know if its the problem, i have to try with one spi, also i dont know if it has solution...
