measuring compression ratio (k1100)
  • measuring compression ratio (k1100)
    without buying anything to expensive , is there anyway to measure the volume of a cylinder head ? (in my case a k1100)
    cheers
    Head on or off Matt ?
      off mate .
        tired looking for the standard for a k1100 head , but cant find it
          Have a look at my build thread.
            Perspex, drill, burette etc to calc cc in the chamber, then a case of calculating any cc dish in pistons + ring land area I think. Pretty sure the info will be in Vizard's bible or on internet.
              I take it you want to work out the volume of each compression chamber in the cylinder head, if you have the valves fitted could you not just pour in a measured amount of water into each of the chambers?
              Gavin
