  • Just found this repair piece on flea bay, https://www.ebay.co.uk/itm/VAUXHALL-...IAAOSwf15aY43w
    • Boom boom that's the bit johnner, I can now mend the bit I took 3 hours to mend that was not broke lol
      Thanks for looking, and thanks for post on last page,
      • You know when you read a post and you think that's eather " not happening" or "I don't believe this" ? That's where I'm at with this, how's about that plastic cog you sent link to obouve being put on 180 out ?
        • If yours is the c20xe dizzy Shaun then you're flogging a dead horse mate. It's just a dumb dizzy to send a spark and nothing to tell it when.
          • Originally posted by NudgerSS View Post
            See my above post John, he has what I’ve researched to be a Cavalier 1.6 8v dizzy
            • Originally posted by InstantCustard View Post
              Sorry Dan I thought you were pointing out what he needed, not what he'd got.
              The plot thickens....
              • Plot thickens to this, I asked about if that plastic bit in eBay link could be on 180 out? Yes it can be I took it off and theres no keyway or locator that only makes it fit 1 way, .
                I'm thinking that if I put it on the other way it will line up with where 1 should be, near the top and not the bottom where it is now, but I'm Shure I would have corrected that on my many combinations of leads,
                • Every picture I have found that shows the firing order shows:
                  1 bottom left
                  2 top left
                  3 bottom right
                  4 top right
                  As you like at the distributor square on.
                  • I really think your overthinking everything and I truly believe there’s nothing wrong with the dizzy, so please stop cutting it up and taking it apart, put it back as it was.
                    You have a spark and the firing order is correct to the pictures I’ve seen dozens of.
                    I don’t know where to point you but I would leave the dizzy for a minute as I think your becoming obsessed with finding something wrong with it.
                    • Yes I'm trying, but it won't start , I have been inside out and upside down, so many times, I have to qwestion it as I've been hear for so long, it may be the coil pack then, I'm trying I'm trying !!!
                      • I'm not with mini at moment coz had to gig away overnight,
                        I took the advice and got seized rocker box off, it was the best thing I've done, it gave me exsact location of no 1 cylinder fire/spark position! I find it was not where it should be! That didn't cause me to much consern as all 4 work the same, now tecknickly speech if you put No1 at no 1 lead and the rest thereafter it should fire all 4 in the correct way, even without carbs a bit of inflammable spray should make a happy fireing sound! But not for long, but I do recognise if that sound is hopeful, but it's not,!! So where dose that leave me? The only place it leaves me is to suspect the dizzy, only because the engine had run well but only for about 7 seconds, but that's enough , if it hadn't ran I would be suspicious of its cam timeline, thank fook that I did hear it fire! So not knowing what the dizzy peg to cam looks like I was convinced it was that, well I would wouldn't I , but it's not that so that's off the list and know I have learnt about that aspect of the 20xe, not a bad thing I must say! The petrol is new and it's getting up, the batt is not the best but it turns well enough, I have exstra earth's from coil pack to engine and the coil is sparkling the plugs nicely in my opinion, but I can't read the sparks , I need a different dizzy , why was it sold to me? Did it ever work? These are things that do cross our minds in this situation! Is there a dizzy replacement that bolts on and takes the reading for crank position sencer, I do still have that in place and it's wire with plug?
                        • That's the cams checked in relation to fireing and rotor arm , well it still won't run, the last part of vid is slowed down hence it sounds strange, now some sparks do look week and sparadick to me, but I'm quite off my trolley jack at the moment,
                          https://youtu.be/VMgeZ5owRhw
                          • If you think you have some weak sparks is possible you have a faulty ignition amplifier? The coil is clearly working as you have a spark.
                            You can test the HT leads by just switching them around and seeing if the weak spark/sparks moves.
                            • Good one !! Worth a try when I get the will to live back lol,
                              • Yeah, unfortunately the only way to test the ignition amp is to switch it with another!
