    So I'm stuck in a traffic jam somewhere in the middle of nowhere and I discover on my phone that I can talk into it and it spells everything correctly I can't believe you lot didn't tell me the do this already so now I can just talk cabbage while I'm able to make sense to everyone oh my god you have done it now I will talk about this problem later it is simpler than it seems it's just I have three things I'm not necessarily trusting and I'm going to bang one out later hurrah hurrah trip over the penny farthing
    hahahahahahahahahaha best post of the year !!
    • We really don't need a video of you banging one out thanks.
        Thanks Daniel the battery is normally charged but I get your point that is their side exit distributor that's ok but I'm at the point where I need not to have to think it's close and it's simple,
        It might be a side exit but the firing order will still be the same.
          I'm glad even the semi French can understand now
          • Originally posted by NudgerSS View Post
            Are you sure Jonah I think you need to ask your gorgeous Mrs Sharon you did say we didn't you,
            • Originally posted by InstantCustard View Post
              Yes point taken Sugar Puffs I got tired and I have done my fair share of trying to swap everything around as best as I can it's very strange that the video just happened that way and it sounds good to just stop and chunk it doesn't always sound like that I suspect that the carbs are chucking too much petrol into one and it's not firing so maybe it's compressing and hydraulic in the piston I need to look again when I'm back this pothole needs to zoom zoom run bug peach
                Can you ask your phone to get your punctuation correct as well please. Commas and full stops would be nice.
                • Originally posted by CooperWorks View Post
                  Yes I will try. This is getting on my wick comma
                  When I say. It does give me a full stop, exclamation exclamation.
                  I'm running out of steam with this it is actually quite simple but it's just going around and around I think something is wrong I have full spark I have full battery when the leads are 180 degrees out easy Start won't even give me a fire I'm lost but I shouldn't be.
                  https://youtu.be/Cun0aNYt7jA
                  • Your going to have to go old school back to basic's! take the rocker cover off get no1 rockers rocking on the power stroke at tdc then see where the disy rotor arm is and try and work it from there? it can only be the way you have set the firing order but this puzzles me in that your not even getting a back fire or pop through the carbs or exhaust? even if it was 180 out there should be sufficient fuel to at least get a misfire from one cylinder.
                    • Yes as you say, it fired up 1st time on the old itb/ECU
                      That took the 1 compression stroke from the crank position
                      Sencer, not in use any more,
                      As you say back to basics it the best apart from my last,
                      I have 2 or 3 rocker box studs that will possibly snap to get
                      To veiw valves/cam,
                      I thought there was 2 dizzys and points dizzy and coil pack dizzy but there seems to be 4 dizzys,
                      Now I have a nice spark and the spark seems to be looking
                      Like it's fireing in a nice sequence, by eye,
                      I don't know but I'm thinking my dizzy don't match
                      My coil pack, I don't have the points type dizzy,
                      I'm old school but I don't want points!!!
                      But would at the moment lol
                      I think I have the old coil type dizzy but I'm useing a coil pack,
                      Hang on, hang on, my coil pack lead is correct to plug into my dizzy, so again the mistory continue,s,
                      • What i don’t understand is you’re getting a good spark, you’ve introduced fuel but not getting any pops or bangs at all. Should at least be backfiring or popping out the carbs?
                        Sent from my iPad using Tapatalk
                        • There is the odd explosion but only from rear exsust,
                          There should be more flaims as you say,
                          I notice them bike carbs have a big slider just like the s,u carb, they do lift by hand but I wanderd if I should jam them open while easystarting spray,
                          • I think I would do a compression test. The engine isn't even trying to fire.
                            Poor Cooper. Looks fed up!
                            • Yes he ain't happy unless he is doing what he wants, just like
                              His mother, I trust the compression as it started good last time it ran, I have just got rocker box like Keith said , to find
                              Number 1 rotor arm position so I can root leads,
                              https://youtu.be/koL9mDCaGy4
                              • I understand your frustration now more than anybody else cause I'm at same problem but with more electricity i.e. Megasquirt...
                                Had spark, RPMs, TPS, temp. sensor’s working, air temp. working, pulse width showing but it didn't start.
                                I was tempted to burn it down but I got to my senses and I'm trying with the system...let's go from the beginning maybe I've missed something...
                                Hop you start it ASAP
