  • Re throttle pedal ratio to carb movement, this is from one of watson's video's what he did was cut about 1" out of the top part of the pedal below where the cable goes into and the cut and weld it into the lower part of the pedal below the bit that bolts to the bulkhead thus changing the pivot ratio. then weld a piece of flat bar below where it should bolt up drill 2 new holes in the flat bat an 1" lower than the original ones and this will move the top of the pedal back up inline where the cable comes through the bulkhead. Simples !
    You can see in this photo the new mounting bracket that raises the pedal back up inline with the hole where the cable comes through.
    IMG_3461 by Keith Thornburn, on Flickr
    • Are you ready?
      https://youtu.be/FX2gzDC6ABg
      • So close!
        • You might want to put a relay into the fuel pump circuit as the switch might not take the constant power that the pump will take and end up melting the switch, you accelerator pedal look's to of been modified already to give extra length above the pivot and you now need it below.
          • Could always try using the pedal from that MPi shell Shaun, it’s slightly different as it has a sprung return, but it’ll be shorter than the one you have there if it’s been made longer.
            • Yes Keith that's noted from you , relay is obviously a protective method of switch, I just did it direct as I did the same on my old minis without any relays in sight, I do hear you though!! I will do that a,s,a,p
              I just picked it up danno, have to fiddle it lower somehow as my top frame rail ect makes it almost impossible to get below the bulkhead crossmember,
              I found I missed a rubber seal in petrol resurve bowl ,
              And when I've tested that I'm gonna take carbs off and hook it all up by a longer petrol line to be able to see where they are leaking, so I hope to sort!
              Then coil pack next as there was not a single spark in earshot, ,
                Another class episode!!
                It's like watching Worzel Gummidge do Car SOS
                No offence meant BTW
                • Don't you start,
                  that name for me disapeard about 5 years
                  Ago , ant Sally
                  • https://youtu.be/uz3BFnSTwJk
                    • Originally posted by InstantCustard View Post
                      https://youtu.be/KxRhEJnyhnE
                      • I was sat here (I’m actually on the loo) thinking what would you be doing with all the horse gear when you don’t have a horse.
                        I think I’ve got it figured out!
                        • More like this!
                          https://www.youtube.com/watch?v=4tNAYqZl6Jw
                          • Originally posted by gadget555 View Post
                            That is quality!
                              • Thing is he look's like on of my managers at work and every time I see him I just have a good chuckle to myself on his behalf
