  • I see you’ve got far with the other shell! LMAO!
    Your vids crack me up, keep em coming
    • Originally posted by NudgerSS View Post
      These videos make me smile [emoji2] [emoji3][emoji3]
      Sent from my iPad using Tapatalk
      At least you have sence of humer!!
      You know "rare up north"
      If you're not ruff. You can touch me ,
      • Originally posted by InstantCustard View Post
        Yes frames off now and gone to Martin,
        Then he finds out that his shell has had the rear floor totally
        Flat plated so no heel bord for frame, opps
        Don't ask!!
        Vids lol I dicided to do vids as YouTube seems safe,
        Ther a pain to make and get points across,
        Building is a pain but look forward to the driving ones later,
        My aim is to get dislikes for being cruel to the mini!!!
        • Been chasing a turn over by key, I did fit a push button
          And it won't work so been untraceing that banana! Not in vid,
          Got it to turn on black box, looking for pump feed and that's backwards to coz it is linked up to a really, yes a relay due to E,C,U now gone but still leaving it's mess!
          https://youtu.be/tV1yTqB-I2Y
          • Cracking on there Shaun! Plenty of progress.
            Will see it moving shortly I’d have thought?!
              Thanks for encouragement, yes progress is good,
              I'm stuck in a way! That, do I or don't I do that job now way,
              I finding that desition hard to make,
              I say( I will paint the tank later, Sunday 1 hour jobs !
              I was Shure I was fitting the exsust system last week,
              Never happened , I have to do the brakes even though the backs where all brand new , I bet they are seazed!
              Anyway forget that and exsust and start up next will give
              A boost,
              • Brakes are new like the day they was put there, something is on my side ,
                I also discover my c,v boots are not correct ,!!
                My fault but I have 6 mm of rubber layed flat on c,v and about 5 mm sacureing clip,
                I want 10 or 12 mm of rubber,, and there is room for it,
                https://youtu.be/BSm0aY83-E0
                • You looked at my suggestion for the pedal yet me luvver?
                    Not yet danno, I said in my head I would fit exsust
                    2 weeks ago , I even believed me lol
                    So felt the need to get it on ,
                    At least I can sit and rev it with 1 inch of throttle lol,
                    • Must be like an on/off switch!
                      Im getting nervous watching you crawl under that car, can I send you some axle stands?
                      • You need to move where the cable is attached to the pedal down a bit and then you’ll have more pedal to throttle movement.
                        • Ive got redtop tiger power.
                          Exactly what I suggested.
                          If I said it and John said it, then it’s gotta work!
                            Well they say great minds think alike so i suppose it must work at the other end of the scale too...
                            • I feard that, that end of cable near pedal has a solid lump on
                              And it's solid in a block that slides into Pedel,
                              Just cut it I suppose , must be easy join after them god damm excuse for carbs ,end)
                              • Just watched the video. Another classic episode if I may say so.
                                Must feel good to get it turning over, actually running in next one hopefully.
                                I have a concern regarding running fuel pipes through sheet steel, without using rubber grommets. It's only a matter of time before one cuts the pipe with untold consequences.
                                Keep at it my friend, soon be done...
