1.6 k series on 10's
  • 1.6 k series on 10's
    Thought it was about time I started my own build thread.
    Ive owned my mini for over 12 years and for the last 5 its been in the garage undergoing a serious makeover!
    I reversed it in one day to replace the radius arm bushes and its not been out since
    A wee spec of rust on the bootlid led to a rub with some sandpaper and an hour later the rear end was stripped
    So since then I have been cutting and grinding, welding and grinding, grinding and welding... you get the idea.
    Since I found this site though a couple of years ago the plan changed and im now going k series
    So some pics of how the car looked and the fateful radius arm day...
    Sorry for the crap images - from now on they are digital
    I should never have carried on with this shell in hindsight, but you know the story "it didnt seem that bad to start with, but it just escalated..."
    I have bought over 20 individual panels for the car and this doesnt include bootlid, doors or flipfront
    Anyway, some randoms of the work carried out...
    work on the boot floor...
    New floor pans, sills and repairs to inner arch areas...
    Checking rear subframe fits in with new mounting points - it did
    Replacing and tubbing rear arches...
    My front end and my Bro's car that I was later to acquire!
    Shagged scuttle area in need of repair. Whole scuttle was replaced in the end
    Scared incase I loose all this so going to upload now.
    Next instalment coming soon...
    The wife doesn't believe you can never have too many tools!
    build diary
    Looks like a lot of work there mate I'm doing the same with mine atm- bit more welding and a lot of bodywork to do before I can even think about my engine build
    But it's looking good!
    Aperture science- we do what we must because we can.
    For the good of all of us.
    Except the ones who are dead.
      I discovered that my roof was rusty - on the inside
      Turns out that my sunroof had been leaking and the water had been running down the a pillar and thats what led to the floorpans and sills rotting!
      Not only that but the water had been soaking the insulation above the headlining and thats what caused this...
      The outside of the roof didnt have a blemish on it, but it was only a mtter of time till it came through
      I could have ground alot off with the grinder but some was very pitted and I wasnt taking the chance of having it finished and regretting it when the bubbles appeared - so just by chance at the same time I took possesion of my Bro's car aswell
      It didnt look too bad but was generally shagged and was pretty much in a lethal state, so.....
      and ended up with this
      took the rest to the local tip in the back of my old mans voyager
      So next was the task of measuring and marking up my shell (about 20 times)
      After bracing the shell... I cut off my roof
      I stepped all the cuts in the pillars aswell as welding plates inside the a and b posts and plates across the inside of the c posts. Ive also welded large tabs to my cage which bolt to the upper seatbelt mounts (dont need these anymore due to harnesses) so I hope the roof is plenty strong again
      So once all the cuts were made the donor roof was strung up and lowered into position. I left a wee bit too much on the donor roof as I didnt trust myself not to end up with a roof chop, and then trimmed away till it was a good fit.
      Thought I should check all the glass fitted
      So it took about two full days to dipose of doner and tack the roof into place, and about another day to finish off the welds and grind down
      All because of a bloody leaking sunroof seal
      You've been warned
      build diary
        Hats off to you for all of that, that is beyond the call of duty
          Your lucky my local tip won't take any car parts let alone a whole car chopped up
          Looks like a very interesting project, keep the pictures coming
          I love my mini
            i recognise your bro's car
            making good progress chap, would it not have been easier to just replace the roof skin?
            [email protected] :)
            Denis.
              The tip didnt really have a choice as we shot in dumped it and left sharpish
              Did go back a couple of days later though and it was all gone
              Evo - how do you recognise the car? Had 13 inch black 4 spokes when it was on the road and was noisy as hell
              Oh and as for replacing the skin - I asked on here and got lots of advice but in the end the thought of trying to find all the spot welds made me dizzy and the inside of the a pillars were buggered too.
              Bhphunter
              build diary
                recognise the car when it cut about wiht the black/polished revo's just seen it driveing about, and i believe ( could be coincidence, i.e. someone else) your bro approached me at the maryhill BP garage asking if i wanted to by some 12" revo's, must have been around the time his car went off the road, a good while back now i think!
                anyways im off out to play in my mini, its cold and dry you should come out for a spin sometime
                Denis.
                  Evo - I'll ask him and see if he remembers. He never had 12's though - only 13's.
                  Dont rub it in that yours is back on the road - youve seen how much I ve still got in front of me
                  So a spin in yours would be very motivating!!!
                  Bhphunter
                  build diary
                    There must be a possability for your bro's car on ebay even now you just need a bit of imagination with the camera and your story
                    Allan
                    Ps I dont want it
                    My new shop http://www.aandgmotorcycles.co.uk
                      I'd have nicked the boot out of it! Save me a job at any rate lol
                        Hi Badger
                        The boot was goosed. The rear valance had actually fallen clean off!
                        The pictures make it look way better than it actually was - hence the reason to cut it up. I saved what I could from it but what went to the tip was scrap. The bumpers look ok in the pics to but the undersides were rotted
                        The only thing I forgot to remove were the straps to stop the bootlid falling open was gutted about them
                        Bhphunter
                        build diary
                          Ah fair enough! Just having a nightmare of a time atm with the boot on mine.
                            Next job was scuttle and bulkhead repairs.
                            I was originally going to just replace the ends but it seemed easier to replace the whole panel than try and align the end in so went for it and it was a breeze
                            Removed old scuttle by drilling out welds and cleaned back the paint
                            Made some repair panels
                            Painted area that will be awkward to get to later and the underside of new scuttle
                            Alignment seems good so spot weld all along top and sides - easiest panel Ive done
                            Bhphunter
                            build diary
                              lmao on the boot straps just looked been a few months ago you last updated has it got any more things done too it and again well done i would have left them for someone else to do as seems alot of work.
                              but at least you no it will be solid for a while.
                              keep us updated mate would like to see it finished or close lol.
                              chris
