Put a bit of black paint on the driveshafts last night so they would be ready to fit today. Had to make a small change to the suspension buffer though. With the suspension on full droop, the driveshaft angle was too steep and it was jamming on the edge of the inboard cv joint. Decided I would drill a hole in the top arm where it rests on the buffer and put a nut and bolt through to make it adjustable. Thought about removing the top arm, but there isn't enough room to remove the shaft holding the top arm on as the gearbox is in the way. So I compressed the rubber cone so that the arm would move up enough to get a drill in there.
Removed the buffer
Arm up just far enough
Fitted the nut and bolt and took the rubber of the buffer
Thanks guys, yeah got the clearances around 10mm everywhere now, the manfold to bulkhead was my main concern as I really don't want to put the plastic one back on.
If you paste this title into fleabay HIGH TEMPERATURE HEAT PROOF Body Paint Steel,Metal,ENGINE,CALIPER Military Army this is what I used, it's about £20 a litre. I got it for painting the engine, but had loads left over so used it on the frame too.
Gearbox steady looks strong. Home brew or adapted from something else? I’ll have to take another look at mine, I’m sure I looked at doing something similar and couldn’t find room.
I hope it will be strong enough. The bushes and threaded bar are from the ultimate engine steady for the A series and the gearbox bracket I made to fit to the available threaded holes on the gearbox. I have about 3mm clearance between the gearbox and steering rack so hopefully it will stop it hitting.
Personally, I think you have your gearbox steady in a perfect position. If you think about it, when accelerating hard, the engine wants to rotate in the opposite direction to the wheels so the engine/gearbox will be pushing your steady together as opposed to mine being pulled apart. Unfortunately, my front bar is too high to position it like yours.
Not wanting to piss on your chips but those lower engine mounts will transmit a lot of vibration (as will the top steady). I used to have a sump mount and gearbox steady very similar but with a mini steady bush instead of the poly bushes you have and they tranmitted a lot of noise and vibration - I removed the gearbox steady and changed the sump one so it used a standard rover/mgf large steady bush and the noise reduction in the car was huge. On the standard mounts the engine doesn't actually move about too much. Of course if you don't mind the noise then it's fine and will help on the track.
Hahaha! Please promise me you will control your bladder when I'm eating my chips. Yeah, I'm expecting plenty of vibration. Bit of a trade off really between vibration or knocking on the steering rack.
