1993 spi cooper MGF
  • 1993 spi cooper MGF
    here we go new project .
    so yes it a 1993 spi cooper with the usual rust.
    going to put new wings and a-panels etc on it.
    i hope to made it look like a nice sports pack cooper.
    i have a nice MGF new MOT on it lol !!! so all good
    going to use front and rear sub-frames ,full loom, power steering.
    The hole MGF in my mini lol. now on a diet
    good luck
    Good luck terry hope the build going well pictures show a lot of well to be done on mini my car had to have a new floor then cut all the boot out
    good luck
      thanks minirich1.
      i got a new bottle of gas today so on whit it .
      going to strip the mgf in two weeks.
        Is that the 1.8 injection engine? if so it's the same conversion that im doing. I have my mgf partly stripped only the dash and loom to come out then the engine. Will be watching this one
          yes it the 1.8i none vvc.
            Similar to my conversion too I guess. I spent a weekend striping the mgf and that got pretty much it all done so doesn't take too long and is quite simple. Do you know how your going to mount the front subframe? Use the mg ones or going to modify the frame like wastons? kit does?
            Project Coxy, Black mid-engined RWD mini. 1.8k-series.. Got the CF bug/NOS...
            Its runnning and had a little drive. http://www.16vminiclub.com/forums/sh...ad.php?t=28324
              am sill running my mgf at the mo. not 100% on the front subframe i wont to keep mini wheels on it but i wont mgf brakes. so re drill the hubs. going to cut down the front and rear subframes and yous a mini rack.
              that the plan i hop.
                started cuting the back out.
                  looking good
                  Hi terryg its looking good so far
                  On you old blue mini you had a set of metro brake on the rear did they pass a mot
                  thank richard
                    thank richard
                    yes the metro brake works very very good but the mot man did look at it people lol.
                    the on 2 mot! i hat to put honda rear brake on it and it was crap than
                      bin on it today .
                      i am not going with mini wheels now i am going to use the mgf one. i found some tyres to fit.
                        You could try using Metro 13" wheels as the PCD is the same. That's what I've done. They just fit over the MG F discs. If you use 175x50x13 tyres there is no need to modify the arches.
                          engine out to moz
                            engine out
                              CHOP up the rear sup today 1"3/4 out got the front wheels on the rear 185 55 15 now 60" wide. the wheels stick out only 4" that ok for me
