  • Been v busy with work. Managed to clock the compressor housing on turbo and work out the tubing from there to intercooler. All going to get quite busy on that side.. 20210501_165733.jpg
    • Thinking about running a Holset HE221W in the future as they seem to give amazing results and reliability. Maybe not bother with the forge dump valve. Will be nice if we ever get a summer to do some grinding and cutting outside, otherwise the other mini gets covered in sanding grit and metal.
      • Been grabbing more bargain for the project... Race alloy Radiator, only £20 delivered! 20210520_170057.jpg 20210520_170031.jpg
        • 3 X cans of etch primer £3, Anderson ump cable for back of car £2, Clamp for water pipes under car £0.50p, Alloy heat reflective tape £1, 3" Exhaust clamps x2 £1. Always keeping the cost low where I can.. 20210522_143550.jpg 20210523_114918.jpg
            • Radiator inlet and outlets look in right place and are the correct hose size. I think Header tank will be approximately as in picture with long pressure / return line to radiator at front. 20210522_143347.jpg
