rwd wide body rust bucket
  • rwd wide body rust bucket
    so i picked a bare shell up three years ago for £20 went down to somerset from s wales to collect it then sat in my garden as a shed for two years i then knocked up a timber workshop [still not finished] and not big enough [a job for summer this year] so far i have fitted new door frame aperature panels a full bulkhead and inner wings when i say fit i mean tec screwed and a few spot welds i had a few cock ups redoing work twice if i wasnt happy with it ect so after picking up a shell for a few bit i needed that had box section inner sills to strengthen it prior to a top chop i thought that would be a good idea on this and anything i then fit can be tied into them they will be welded to the a and b posts and the rear arches
    so i have a redtop xe lump as well as a set of webber 45 carbs and inlet manifod.. an allspeed subframe and arms mounts ect from a guy on here .
    but i got to thinking ide like a rwd mini with front mounted engine.... so a drunken evening on ebay got me the following a box section kit car chassis narrow and short only 300 mm longer than a mini wheel centre to wheel centre
    easily shortened its ford based cortina front clip and escort 4 link rear with panhard rod from outriger to outrigger its 35 n half inches and inbetween the box section sills i have 41 and bit so will fly in make a new tran tunnel and bobs your uncle thats 1 option another is a sierra rear subframe with the shell strengthened and modified so it can bolt on with a new fabricated boot floor i also have a full running gear set from an mx5 and a race tuned mx5 engine and box i picked up for 75 quid now i know this is not normaly done not seen it at least and maybe for good reason so thoughts are welcome be gentle
      few pics of potential running gear the engine on that chassis in the pic is an iveco 2.8td so i think i will be pretty free to run a lot of rwd motors tbh oh yes the distance between the strut tower outer edges is 630 mm so again flies into the mini in fact i would re engineer that section so they sit nearer the standard mini shock position so as to keep some boot floor
        i have a fortec kit and ive seen a box arched clubman i really like and wouldnt mind doing something similaire the difference between the ford and mini rear track is around 200mm the fortec covers that no problem if i use that kit or i could get 100 mm a side if making steel box arches
