Project: poopercharger (cg13de micra)
    No idea yet, not fitted yet.
    Hope soon though
      Do not put a band on that right driveshaft inner joint boot at this stage. I couldn't fit the pot joint through the hole in the subframe so fitted the pot joint to gearbox then slid the driveshaft, boot and inner cage through the hole. Grease everywhere!
        Think we broke the gearbox [emoji24][emoji24][emoji24]
        Think it was in gear when we started it up without any shafts in [emoji15]
        Fuck!!!!
        • #49
          Got a few jobs sorted today, battery cables, throttle cable and mounted flip front.
          Car sounds amazing
          Was gunna put shafts on, but wouldn't go in.......think we left it in gear whilst engine was on with shafts out at some point [emoji15][emoji15][emoji15]
          Is it salvageable?
          • #50
            https://youtu.be/HqEv21bhFPU
            • #51
              Loving your work
              • #52
                What ecu are you using
                • #53
                  It's a megasquirt clone
                  It's sold here as a redline developments ecu, but it's a k-data unit
                  • #54
                    Hi mate, hope all is well. Any chance in a couple of photos of the front subframe? Or underside photo showing clearance for the sump? No problem if not. Thanks
