Project: poopercharger (cg13de micra)
  • Project: poopercharger (cg13de micra)
    Well loosing all my thread sucks!!
    Here's a quick re-cap from photos I've managed to find
    Homemade frame
    Repaired rear subframe
    Supercharger/inlet manifold made from various old manifolds
    Homemade exhaust
    New water pulley made to be inline with other pulleys
    Clutch pedal
    Brake servo relocated to passenger side, made a cam bar with a few rose joint connectors
    Would of used original m/c, but charger covers the holes
    Car now rolls on its wheels for first time in its new life
      looks like we have matching wheels.
        Inspired by all the cool minis at retro show at Santa pod, decided to pull my finger and get back on the car
        Injection pumps and stuff sorted with return welded onto the tank
        Brake lines done
        Should have this soon too
          Coils and injectors wired up
            Anyone used one of these?
            http://www.carbuildersolutions.com/u...-wiring-module
              Yeah I have, good but of kit and easy enough to wire up aswell. I've used it but blended it in with mini switches, stalks etc and so far it's all working great. Only thing is may need to add an extra fuse box if your planning on using more electrical components than the module has room for. Check out my diary of you like. Cheers
                Cheers will do
                  Can I just ask... did you beef up that subframe in certain areas, as it looked pretty weak in some areas from earlier pictures. I know its a micra engine, but now you've a supercharger and the engine / trans loads are just one aspect.
                    Sorry not trying to cause grief but rather avert it.
                      No problem mate.
                      Yeah, triangulated some parts and extra bracing here and there
                      Had some photos, but lost when the server crashed and could only salvage what I've reposted
                      I'm confident it's strong enough
                        Originally posted by no-dice View Post
                        No problem mate.
                        OK cool. It's just sometime earlier in builds, frames not unlike tv stands are created.
                          I've looked over a few frames, also the allspeed type, so just copied those really and strengthened where I think looks like it needs it
                            Ecu wiring 99% done with relays fuses and switches
