B18C4 City (aka City-R)
  • B18C4 City (aka City-R)
    just thought id introduce my vtec project.
    its a 998 city with a flip front, I part ex'd it with cash for my 91 cooper.
    the plan is b18 conversion, compomotive turbos with pearl grey paintwork and a few extra bits.
    https://www.youtube.com/watch?v=hoqKgqHeof8
    EP82 - B18c4
    Follow my build - https://www.youtube.com/playlist?lis...aeJnpn_8bK0ooS
    Thank you for the walk around, that's probably the best introduction into a project I have seen within this 16v mini forum.
    Was that a single upswept dtm exhaust = (scrap!)
    Minicharged - Honda + Turbo = PoWeR.
      haha yes mate sold it on for £40 (it was nearly new condition).
      its not as detailed as i could of gone but the bare basics of my plan
      EP82 - B18c4
        UPDATE - everything a-series in the bin
        As you can see everything a-series out.
        998 in the bin
        exhaust off
        fuel lines are next for the bin
        as you can see honda wiring 'looming' around, will start tucking into the splicing mission i have this week in preparation for the subframe arrival
        EP82 - B18c4
          Swift progress!! £40 every little helps when doing a project such as this. I currently have £9500 in a b18 turbocharged with 2 stage nos @ 407bhp .
          I will continue to follow your updates turbominicooper,
            The Sicness! sounds insane. Cheers
            EP82 - B18c4
              split rims rebuilt!
              rolling on Compomotive Turbo's, 8x13 on rear and 7x13 on front.
              I made an error with tyre sizes as i bought 60mm walled and these dont fir the rear, just waiting to have everything built up to see if i can use the 60s on the front plus might help having a bigger wall given the weight on the front etc (if thats even a factor).
              just need to get my extended wheel studs sorted and order my carbon miglias
              EP82 - B18c4
                You may find that the sidewall flex on that profile tyre may well induce extra factors to torque steer
                  you reckon? its trial and error, I don't even know if the 60mm wall will hit anywhere on the front yet. will have to see and report back
                  EP82 - B18c4
                    minor progress this weekend as i got caught up sorting a decat on my starlet.
                    managed to get the fuel pump modified and re-wired to suit the mini standard mini tank:
                    also managed to do the work required to de-immobilise the ecu, big thanks to ECU-MAN @ ozhonda.com for the tutorial
                    http://www.ozhonda.com/forum/showthr...ht=immobiliser
                    EP82 - B18c4
                      Subframe has arrived!
                      EP82 - B18c4
                        That tutorial link doesn't work. Do you need to register
                          works for me and im not registered
                          EP82 - B18c4
                            Weird it works now.
                              so as i said the other day, the subframe has arrived!
                              its an allspeed unpainted subframe kit with mounts, bottom arms, relocation brackets and drive shafts (unbuilt):
                              https://www.youtube.com/watch?v=zDx5wIMek44
                              i put the frame in and was about to kick off about the top mount holes not lining up until i read the instructions stating this was the case and how it should be:
                              a mock fit of the engine and everything sat as id expect, overall impressed with the build quality at allspeed, thanks Rob:
                              next question was 'whats next?' so i started on the wiring nightmare. 6 hours later and id cabled up most of the passenger side loom to the ecu along with half the pgmfi relay and other relays:
                              https://www.youtube.com/watch?v=NaLphQxuLXs
                              to be continued...
                              EP82 - B18c4
