B18B1 MTB1 Racer
  • B18B1 MTB1 Racer
    Though it was time i take my courage with both hands and try to speak english a little bit so i can share my projet with you guys. My build thread is already on an french canadian forum but there is a lot less people to speak with there.
    Here is the story:
    Bought the car in 2000 when i just finished shool.
    Spent the next winter doing a bare shell rebuild with the help of my father. After a few weeks using it on the street, i began to feel the potential of the car for racing. I then started to modify it with good shocks, S brakes, engine mods, slicks and shell lightening...
    After a few years racing it and pushing the A series to its limits(affordable limits) i went to an event where a guy with a D15 Honda engined Mini beat my time by 1 second.
    Last race with the A series engine:
      The next day, my decision was made, i needed a 16vMini. Living in appartment and having nearly no tools at that moment(2006), i went for a Minitec MTB frame with extended fibre front end. Found a wreked Integra RS as a cheap donor.
      I then opened the thorax
      Removed the heart
      Made some place
      added a new heart
        Good looking mini you got there.
        at Pod' ran 11.2 @ 122mph allmotor 1.5 60ft at pod. now building a mini
        http://www.youtube.com/watch?v=UzbJtb_VZ9c
          The following season, i had a better weapon to fight against the modern beasts in the club.
          First race with the Minintegra
            what she looked like last summer
              not a fan of extended fronts but looks good, thought you said you went with mtb kit, is that the old mtb kit?
                I love the black on black look but you need black wheels too lol.
                What tranny and FD?
                  Really like the look of that, I've been thinking about painting a lot of the chrome black on my mini looks very tidy. What strip do you use on the windscreen instead of the chrome type one?
                    I've bought the black screen strip for mine but I haven't got round to fitting it yet.
                    http://www.minispares.com/Product.as...d=37184&title=
                    Suck, Squeeze, Bang, Blow.
                      After racing the car for three years with the Honda engine, what i missed the most was the "go kart" handling of the original Mini. The Honda engine is heavier and weight is all in front of the axle. I never felt confortable with my hybrid Mini when entering a curve, the back end is becoming too light under braking. Oversteer on a traction is not my favorite thing...
                      Last winter, i undertook some weight distribution improvements. I want to remove some weight in front of the axle.
                      I started by replacing the heavy cast iron exhaust manifold by a lighter tubular header. Stainless steel 4-2-1
                      Then i saved about 8 pounds with this aluminium crank pulley
                      so had to make a new tensioning bracket because Minitec one was now innapropriate
                        Once started, why not take some weight in front and move it to the back
                        I drafted some shrouds and had then laser cut and bent
                        Not the usual way to fill a rad
                        This fan needs air to suck throught the rad and i tought the easiest way to provide it was from NACA ducts in the rear side windows.
                        Then trought the useless speaker holes...
                        Front dry fit
                        Bleeding during the fill up
                        You can't afford a tool, fabricate it
                          Everyting is there but it's tight fit
                          To make room for everybody, i had to move link inside. By the way, i'm putting it closer to the steering wheel so race car ergonomic is coming
                          So now i can have a beautiful straight line
                            I was not about to cut on my rust free original boot lid so decided to mould one out of carbon fiber. It's my first time doing such a big part, not an easy task...
                            now with a duct
                            don't worry for the finish, i plan to add a layer of carbon-kevlar on top of it so orange peel and color mismatch should go
                              In addition to poly engine mounts, i made this ultimate steady using old Mini tie rods. It worked on the A series so why not on the B series
