Old 07-07-2016, 05:08 PM   #1
Aband
Aband's Avatar
Make: Ford
ECU: Jolt
Send a message via MSN to Aband
Default Drive shaft sleaving service
Good day to all.
Its been a long time since ive been on this forum as i left the country for 2 years but have returned and have my own machine shop set up.
I used to sleeve a lot of peoples drive shafts and do quite a few custom machining jobs and am now offering my services once again,
any inquiries please dont hesitate to send me a message on here or to my email address, adam@noath.co.uk
Adam
Aband is offline   Reply With Quote
Old 07-07-2016, 06:03 PM   #2
Doodling
What sort of price are you looking at for a pair of Honda shafts?
Doodling is offline   Reply With Quote
Old 07-07-2016, 06:09 PM   #3
Aband
Aband's Avatar
Make: Ford
ECU: Jolt
The cost to cut and sleeve your original shafts is 55. You will need to send me 2 mini shafts and two Honda shafts providing your using mini hubs. You also need to let me know the lengths you need them to be.
Cheers Adam
Old 07-07-2016, 06:24 PM   #4
Doodling
Originally Posted by Aband View Post
The cost to cut and sleeve your original shafts is 50. You will need to send me 2 mini shafts and two Honda shafts providing your using mini hubs. You also need to let me know the lengths you need them to be.
Cheers Adam
I'll be in touch when I'm ready mate.
Old 07-07-2016, 06:27 PM   #5
Aband
Aband's Avatar
Make: Ford
ECU: Jolt
Okay no problem.
Could one of the mods correct my spelling mistake in the title?
Old 07-07-2016, 08:00 PM   #6
VTEC JON
Hi,I am looking for someone to do my driveshafts,Exeter is a long way though,would posting them be a possibility?
VTEC JON is offline   Reply With Quote
Old 07-07-2016, 08:03 PM   #7
Aband
Aband's Avatar
Make: Ford
ECU: Jolt
Sure posting them is no problem. I will send you a PM with the address to send them to.
Old 07-07-2016, 08:36 PM   #8
marlinman
ECU: standard honda
great to hear you are back with us, you were sorely missed. your shafts still in one piece despite the abuse.
john
marlinman is offline   Reply With Quote
Old 07-07-2016, 10:07 PM   #9
about time lol, where you based?
Old 08-07-2016, 05:09 AM   #10
Welcome back!
Old 08-07-2016, 02:59 PM   #11
Good day to all.
any inquiries please to hesitate to send me a message on here or to my email address, adamnut111@hotmail.com
Adam
I am interested to know if it is possible to machine a Mini end on to a different shaft, be it Honda/Rover/Vauxhall etc. The shafts are all bigger than a Mini one so would have enough material on them to turn them down and spline them to suit. Doing them this way would mean they were not cut so hopefully stronger.
I don't need any, but these do seem to be causing issues for others.
Old 08-07-2016, 04:05 PM   #12
Aband
Aband's Avatar
Make: Ford
ECU: Jolt
Thanks guys
ardonfast - Im only in Crediton so not to far away from Dunkerswell.
AGoaty - Providing the sleeving is done correctly it will be very strong anyway. I think from memory the weakest part of the shaft is the mini end where the circlip stop is, as its quite a deep groove and seems to be the weak spot. Also once you turn down a drive shaft to a smaller size you remove its harden shell as the drive shafts are heat treated to make them stronger. This then makes the part you'd want to cut a spline into soft and would probably need re hardening.
I have the machinery to do the splines just not the tooling. Once i get some tooling ground up i can give it ago and report back with a cost. But sleeving is the cheap and cheerful way to go.
Old 08-07-2016, 08:53 PM   #13
Starmag
Now I know where I recognise your use normal from! Minifinty? I bought a 1275 engine from you about 7/8 years ago!
Starmag is offline   Reply With Quote
Old 08-07-2016, 10:16 PM   #14
cookie4343
How much to cut and sleeve 2 mini shaft with Citroen saxo shafts, also what's the best way to measure, thanks Steven.
cookie4343 is offline   Reply With Quote
Old 09-07-2016, 08:11 AM   #15
Aband
Aband's Avatar
Make: Ford
ECU: Jolt
Ha yeah used to be on there. I moved out of that house about 9 years ago so 7/8 will be about right!! How did you get on with it? I see you've gone for something abit bigger now.
Cookie4343- 50 for the pair plus postage if you posting them. Best way to measure is to push the hub up to the top bump stop and measure from circlip groove to circlip. Or cut you shafts over sized so you can fit them both in. Allign them side by side and scribe a line
Cheers Adam
