Old 08-05-2012, 08:06 PM   #1
terryg
terryg's Avatar
ECU: rover MGF
Default 1993 spi cooper MGF
here we go new project .
so yes it a 1993 spi cooper with the usual rust.
going to put new wings and a-panels etc on it.
i hope to made it look like a nice sports pack cooper.
i have a nice MGF new MOT on it lol !!! so all good
going to use front and rear sub-frames ,full loom, power steering.
The hole MGF in my mini lol. now on a diet
terryg is offline   Reply With Quote
Old 09-05-2012, 06:20 PM   #2
minirich1
CC: 2ltr 8
Talking good luck
Good luck terry hope the build going well pictures show a lot of well to be done on mini my car had to have a new floor then cut all the boot out
good luck
minirich1 is offline   Reply With Quote
Old 09-05-2012, 07:05 PM   #3
terryg
terryg's Avatar
ECU: rover MGF
thanks minirich1.
i got a new bottle of gas today so on whit it .
going to strip the mgf in two weeks.
Old 09-05-2012, 08:31 PM   #4
1275stu
Is that the 1.8 injection engine? if so it's the same conversion that im doing. I have my mgf partly stripped only the dash and loom to come out then the engine. Will be watching this one
1275stu is offline   Reply With Quote
Old 09-05-2012, 08:40 PM   #5
terryg
terryg's Avatar
ECU: rover MGF
yes it the 1.8i none vvc.
Old 10-05-2012, 01:07 AM   #6
richh999
richh999's Avatar
Similar to my conversion too I guess. I spent a weekend striping the mgf and that got pretty much it all done so doesn't take too long and is quite simple. Do you know how your going to mount the front subframe? Use the mg ones or going to modify the frame like wastons? kit does?
Project Coxy, Black mid-engined RWD mini. 1.8k-series.. Got the CF bug/NOS...
Its runnning and had a little drive. http://www.16vminiclub.com/forums/sh...ad.php?t=28324
richh999 is offline   Reply With Quote
Old 10-05-2012, 10:28 PM   #7
terryg
terryg's Avatar
ECU: rover MGF
am sill running my mgf at the mo. not 100% on the front subframe i wont to keep mini wheels on it but i wont mgf brakes. so re drill the hubs. going to cut down the front and rear subframes and yous a mini rack.
that the plan i hop.
Old 13-05-2012, 06:16 PM   #8
terryg
terryg's Avatar
ECU: rover MGF
started cuting the back out.
Old 19-05-2012, 07:19 PM   #9
minirich1
CC: 2ltr 8
Default looking good
Hi terryg its looking good so far
On you old blue mini you had a set of metro brake on the rear did they pass a mot
thank richard
Old 19-05-2012, 10:01 PM   #10
terryg
terryg's Avatar
ECU: rover MGF
thank richard
yes the metro brake works very very good but the mot man did look at it people lol.
the on 2 mot! i hat to put honda rear brake on it and it was pineapple than
Old 19-05-2012, 10:15 PM   #11
terryg
terryg's Avatar
ECU: rover MGF
bin on it today .
i am not going with mini wheels now i am going to use the mgf one. i found some tyres to fit.
Old 20-05-2012, 10:12 AM   #12
You could try using Metro 13" wheels as the PCD is the same. That's what I've done. They just fit over the MG F discs. If you use 175x50x13 tyres there is no need to modify the arches.
Old 27-05-2012, 06:16 PM   #13
terryg
terryg's Avatar
ECU: rover MGF
engine out to moz
Old 28-05-2012, 08:31 PM   #14
terryg
terryg's Avatar
ECU: rover MGF
engine out
Old 29-05-2012, 08:25 PM   #15
terryg
terryg's Avatar
ECU: rover MGF
CHOP up the rear sup today 1"3/4 out got the front wheels on the rear 185 55 15 now 60" wide. the wheels stick out only 4" that ok for me
