Old 12-08-2008, 08:54 PM   #1
matt
matt's Avatar
ECU: Mems 3 Z&F
Default Engine power to weight
Engine ------- BHP/RPM ------ BHP/WEIGHT
MINI COOPER S 1275 CLAIMED 76bhp 0.69 BHP/KG
Vauxhall C20XE 150 @ 6000 1.07 BHP/KG
DURATEC 2.0L 140 @ 6000 1.16 BHP/KG
SUZUKI G13B 105 @ 7500 1.16 BHP/KG
1.8 KSERIES 120 @ 5500 1.25 BHP/KG
TOYOTA 1.9VVTI 189 @ 7800 1.30 BHP/KG
HONDA B16 160 @ 7600 1.52 BHP/KG
1.8 KSERIES VVC 160 @ 7200 1.66 BHP/KG
1.8 KSERIES VHPD 184 @ 7000 1.91 BHP/KG
Suzuki 80kg
Rover k series 96kg
Honda b16 105kg
Mini A series 110kg
Toyota 137kg
Vauxhall 140kg ?????? carnt find manufactor weight
Mini cooper s engine from 1965 is said to be 76bhp but they were proberbly all diffrent.
Found the ford 2.0litre already worked out on internet so dont know weight?
I was a bit bored so i found out how heavy engines are to how much power they have. You can work this out by bhp divided by engine weight.
formula = engine wet weight with no gearbox (kg) divide by engine bhp
c20xe was 140kg
I think this is wrong so if eneybody knows the proper weight with no gearbox please post and i can edit this. The other engines are manufactor weight so are accurate. But some might be with ancillares and others not. I know the k series is 96kg with and without its 78kg.
Rover no show and all go!!!!!
Old 13-08-2008, 11:06 AM   #2
99fusion
G13B is about the same as a mini engine I think, around 110kg i seem to remember reading not far off anyway. G13A had 3 cylinders and was SOHC and weighed 63 kg. With a bit of extrapolation (both alloy blocks), at 21kg/cylinder thats 84kg +extra weight of DOHC cylinder head, you definately could say around its around the 100kg mark...
So what does that make the approximate engine to wieght ratio for G13B (100bhp) ?? :P
Old 13-08-2008, 11:46 AM   #3
Hi,
G13B has 105Bhp std and weight 110kg with gearbox.
So, gearbox is 27Kg without oil... you will be talking 80Kg.
1.31Bhp/kg
I can find out what rev is for max power.
Atchi
Old 13-08-2008, 11:48 AM   #4
LOL this thread wud have to be started by a k-series person! I'm sure the g13b. Is comfortably under 100kg
Old 13-08-2008, 11:56 AM   #5
could the weights of the engine please be added to the thread
regards
Matt
Old 13-08-2008, 01:32 PM   #6
imported_mini1
regards
Matt
Just so all the Vauxhall 20xe guys feel like they have to now go on a diet!!
Been on the road 12 months now, and im still working on it way too much!
Regards Paul
imported_mini1 is offline   Reply With Quote
Old 13-08-2008, 02:27 PM   #7
mininut
ECU: Trionic 5.5
Originally Posted by mini1
regards
Matt
Don't matter mate, there's more torque than the other engines to pull everything along
M.
Old 13-08-2008, 03:18 PM   #8
mrbell
CC: 1324
Send a message via AIM to mrbell
Somewhere once upon a time I remember reading the Suzuki is 98kg. Going off of Atchi's numbers, I'm guessing that might be the wet weight.
I have to take exception to 99fusions implication that the G13B is about the same weight as the mini engine. I've picked up and carried around a g13b long block and that was heavy but doable. The gearbox is pretty lightweight too. I've carried it around w/ one hand. On the other hand, it took 3 people to pull the A-series out of the back of my wagon and that was just to get it onto the ground where we could slide it around.
Obviously, not back to back, apples to apples comparison, but the A-series is a huge chunk of iron while the G13b is all aluminum. I'd be really surprised if they were within 25kg of each other...
mrbell is offline   Reply With Quote
Old 13-08-2008, 05:25 PM   #9
99fusion
Originally Posted by mrbell
On the other hand, it took 3 people to pull the A-series out of the back of my wagon and that was just to get it onto the ground where we could slide it around...
maybe... i just remember reading somewhere that the a-series engine weighed 98kg, but then i may be way off - u know those "i seem to remember figures... most acurate ... It took a struggling me and my dad to move the A-series engine block into a corner of the garage, that and lots of swearing/red faces
so does that mean you swifties with rubber suspension have an even bouncier mini than normal?!
edit:... hmmm maybe that 98kg was the g13b... those uni years don't half wear on you
Old 13-08-2008, 06:05 PM   #10
matt
matt's Avatar
ECU: Mems 3 Z&F
I carnt find the weight of a mini engine eneywhere. If eney body knows eneyother engine that possobly would fit in a mini and knows the weight please post it so i can put it on the table. Even bike engines.
Old 13-08-2008, 07:00 PM   #11
99fusion
aha ha! Gotta love the good old haynes manual, got me through countless times of damn how does this thing go back together again? after stripping the mini a couple of years before...
may i quote, Haynes manual, MINI '69 to'89, Chapter one, Section 5, subsection:
"The engine/transmission unit weighs approximately 330 lb (150kg)"
I thought i'd seen it somewhere... was only 40kg off.. :P
so how much does the gearbox weigh?, and 7.38l of oil? +3l of coolant (3kg if approximately same density as water)?
edit: forget the fluids, from re-reading that section sounds like it's 150kg without the fluids. down to interpretation really but within approx 10kg of 150...
edit 2: or is wet weight = with fluids...?
Old 13-08-2008, 07:08 PM   #12
99fusion
regards
Matt
and torque too if possible?
Old 13-08-2008, 07:13 PM   #13
imported_ludsonline
What you want is one of these babies.
Hayabusa V8 twin Turbo
650 BHP and only 90KG
7.22 BHP/KG.
http://www.h1v8.com/page/page/1562068.htm
imported_ludsonline is offline   Reply With Quote
Old 13-08-2008, 07:46 PM   #14
matt
matt's Avatar
ECU: Mems 3 Z&F
7.22 BHP/KG.
That is the engine you need to make the fastest mini down the strip. Would beat that yellow v8 mini
Old 13-08-2008, 08:18 PM   #15
650hp and 0.001ft'lb thatd be great for city traffic.
im quite sure a B16 ways more than the k/S2000 series lumps!? and im sure the k/s2000 dont weigh that much!
*cant mind the leter given o the s2000 engines f-series?!?
