Hi
I'm looking at scissors lifts and I need to find out whether the one I am looking to buy will actually allow the car body to be lifted free of a subframe when everything is disconnected or whether the lifting part will over hang the subframe meaning it cant lift the body off the frame.
I am at work and my car is miles away locked in a garage. If any one has quick and easy access to a tape measure and a Mini Saloon would they be able to just do a quick measurement along the lower sill just under the seam from the back to the front of the flat part of the sill as this will give me an approximate measurement of the floor pan so if the lift is longer than that then the lift will foul the frame when the car is lifted. If measurement is very close then it probably would be possible to move the car slightly forward from centre to give enough clearance but if its miles out then I'm stuffed and back to the drawing board.
