Old 18-07-2017, 12:51 PM   #1
Default yourshire copper joint
can you solder a copper round joint onto aluminium?
my power steer pipe has rubed through ,pug 206,
i dont like the look of the pipe conectors and never done them,
looking for bodgedodge lol
Old 18-07-2017, 04:58 PM   #2
McMini 22
Pretty sure you can't solder aluminium.
You could epoxy an aluminium patch on to it but you'd have to clean the pineapple out of it.
You could try that low melting point Ali welding stuff. Comes in loads of trade names. Lumiweld springs to mind. But for the price of it you would probably be better off with a second hand pipe.
Old 18-07-2017, 05:47 PM   #3
andyfkettle
andyfkettle's Avatar
Possibly be brazed together.
Old 18-07-2017, 06:32 PM   #4
If it's the high pressure side your only viable bodge is a compression fitting with metal olives. If it's the low pressure side jbweld will be fine.. if your keeping the car more than a few months, buy a new pipe.
Old 18-07-2017, 06:39 PM   #5
To add 206s have an issue with hairline crack forming where the steering pipes and valve body section of the rack join the main body of the rack. If the leaks in this area it's a real spring possibility. Proper cure is a new rack. The help a broke customer cure is to apply a light vacuum to the ps reservoir. Clean the hell outta the crack and drown in jbweld.
Old 18-07-2017, 08:01 PM   #6
aye, all points considerd, thanks,, im a ruff bustard coz i have awhole 206 growing into the brambels but dont like the look of the pipe joiners> from rubber to alloy(look like miniture c,v boot clips(metal,,proper tool,) and me not being a mackanical lover lol
i gone halfrauds and got evostik matel epoxy putty, well the large print reads well lol,
so i dinykenn if its high pressure sidebut by the looks of it its 12/13 mm alloy and the other pipes look harder and dark in coulor, so lets hope its low pr,
i cleaned with whit spirit and set lite with blow torch to clean,
its up top so not the rack pipe issue you mentioned,, and its a dented rub through caused but the 2 top sucureing clips being broke and chaffing,
lets try and see what gives, lol
Old 18-07-2017, 08:26 PM   #7
McMini 22
I'd love to read your risk assessment for this!
I've always found white spirit leaves a bit of an oily film. Try some of your nail varnish remover!
It will seal better if you glue a patch on rather than just a blob of epoxy.
I fixed a clutch pressure regulator on volvo 850 tdi by epoxying a 2p piece onto it. I'm not proud of this but it lasted for a year and was still there when I sold the car!
Old 18-07-2017, 08:41 PM   #8
what the fook is risk ass,sessment
good piont about whitespirit,, blow torch sorted that,, well i hope
good point on coin too but to late, 1st mix when hard in my hand so was faster on 2nd
Old 18-07-2017, 11:03 PM   #9
McMini 22
Aye! When it goes hard in your hand you have to be fast!!��
Old 18-07-2017, 11:15 PM   #10
currychef by Shaun Wells, on Flickr
Old 18-07-2017, 11:19 PM   #11
, all fixed hardonfast,, had to shair my first dowload vidio. to flicker while things are going well, time to celibrate with we dram,
Old 19-07-2017, 11:37 AM   #12
So you got your Flickr account working then
Old 19-07-2017, 12:28 PM   #13
sortof oz, long story, i have 1semismart phone 1 laptop 1 big mainframe computer, i have most my pics on big computer, not with me most of the time,
i know how to take pics and vids on semiphone, motarola, will do job,
i have lots of vids/pics on it but cant get flickr on it or workout how it can upload to flkr,
i have semi cracked flickr on this cRap laptop, but it dont have any vids/pics in its download section!! so i have nearly got,the,lot!
i found>download button on photofookit as directed but it dont show in my download dipartment of laptop!! it must have failed to download,
i will try again later, but im diturmend to delete nearly 50% of pics i dont want to download,
but photobukits deleate system is so slow to use its painfull,
i decided to get rid of stuff as i dont want it takeing space up on download,
Old 21-07-2017, 08:39 PM   #14
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
It's the semi smart user that's the issue.
I ended up downloading individual photos onto my ipad as the album link wouldn't work
Old 21-07-2017, 11:40 PM   #15
happy birthday johnner. will try 1@ time, hope you like your presant,
VVVVVV VVVVV hear
