Old 14-03-2013, 09:41 PM   #1
mercenary62
ECU: std
Default centre mini speedo with c16se/3.55xe box
hi im currently building a c16se conversion for my mini ,im using a 3.55 xe gearbox and would like to retain the old centre mounted speedo ,im also running 10" wheels ,is it possible or will i need some kind of devise to let me get the correct road speed registering on the speedo if you see what i mean? thanks in advance
mercenary62 is offline   Reply With Quote
Old 15-03-2013, 10:34 AM   #2
Beats
Beats's Avatar
ECU: Motronic 2.8
Look on the speedy cables website. They can make a cable for you and calibrate your speedo if you supply some basic info which is all detailed on their site.
Beats is offline   Reply With Quote
Old 15-03-2013, 12:02 PM   #3
mercenary62
ECU: std
thanks mate will do
Old 15-03-2013, 01:54 PM   #4
pob
ECU: Vauxhall + superchip
As above Speedy Cables will make you a 1 off cable with a vauxhall gearbox connector and mini speedo connector and recalibrate your existing speedo.
I think it was nearly 200 that I got quoted.
(But take their estimated delivery times with the preverbial pinch of salt )
Or buy a cheap old satnav and just run it on the speedo function.
pob is offline   Reply With Quote
Old 15-03-2013, 02:36 PM   #5
200 qwids, feanin sods, i want gold one for that,
Old 15-03-2013, 05:15 PM   #6
mercenary62
ECU: std
holly bananas they must make a fortune think il maybee get a cable off them ,but feck the recalibration ,speedo does not need to be working for mot anyway it just needs to be there
Old 15-03-2013, 06:26 PM   #7
pob
Oops, just remembered that included getting the rev counter changed to accept the signal from an ecu aswell as the cable, recalibration and postage.
That was a few years ago, dont know what their prices are like now.
Old 15-03-2013, 06:31 PM   #8
mercenary62
ECU: std
ah thought it was a bit dear im on about the large centre clock with the gauges at either side as on 60s 70s minis the old smiths stuff
Old 15-03-2013, 07:05 PM   #9
Can you cut and join the cables with a brass joiner, it works if you have a outer bit to keep the outers apart,??
Old 15-03-2013, 07:22 PM   #10
mercenary62
ECU: std
thanks mate i thought of that might give it a go ,il phone speedy cables tommorow to see what theyd take to make a cable ,on the lookout for centre speedo with the gauges either side now
Old 15-03-2013, 08:05 PM   #11
Beats
Beats's Avatar
ECU: Motronic 2.8
They quoted me around 30 plus postage to make me a cable.
Old 15-03-2013, 08:21 PM   #12
mercenary62
ECU: std
thanks mate will confirm with them tommorow
Old 15-03-2013, 08:37 PM   #13
Beats
Beats's Avatar
ECU: Motronic 2.8
That was for a centre speedo like yours and a vaux f20 box. I did supply both ends of the 2 cables though- not sure if that makes a difference re price.
Old 15-03-2013, 08:46 PM   #14
cooper_mark
cooper_mark's Avatar
or if u have an iphone use one of the iphone apps that work from gps...not sure how accurate they are tho
my beast
Old 15-03-2013, 08:59 PM   #15
mercenary62
ECU: std
yeh mate ,id want to keep the centre speedo so gps for me is out
