Old 29-09-2018, 04:01 PM   #151
jackjewell93
ECU: Emerald
Thinking of selling up not sure if to keep the car complete or strip for parts
Old 29-09-2018, 07:14 PM   #152
chabbly vvc
chabbly vvc's Avatar
Itís not April fools yet mate 🤨
Old 29-09-2018, 10:49 PM   #153
Been there mate. Got loads of T shirts.
If you do, you will be back...
p.s. I might need a shell...
Old 30-09-2018, 11:40 AM   #154
Your weird jack ! how much do you want for this liability ?
Old 30-09-2018, 12:13 PM   #155
jackjewell93
ECU: Emerald
Probably want to much cant really see it been worth much
Old 06-10-2018, 09:20 AM   #156
Broomel
Not worth f all mate, drop the shiny bits up here and just weigh in the rest
Old 23-10-2018, 08:20 PM   #157
jackjewell93
ECU: Emerald
Stopped sulking and decided to get on with it. Fitted the gt2560 also purchased some scales and turn plates to properly set the suspension up!
Old 03-11-2018, 07:56 AM   #158
jackjewell93
ECU: Emerald
Finally put the scales to use and set the corner weight. Total weight of the car was 662kg with half tank of fuel
Old 03-11-2018, 08:03 AM   #159
Have you added your weight and put that in the drivers seat? Then you can corner weight the car - easier to do with a mate sitting in drivers seat , otherwise you have to stack a lot of weight to simulate the driver
Old 03-11-2018, 03:05 PM   #160
Would love to know who drempt up this corner weighing thing? Ok for a fixed car that only has 1 driver seat I suppose!
Old 03-11-2018, 07:46 PM   #161
jackjewell93
ECU: Emerald
Yeah loaded up the drivers seat to match my weight
Old 03-11-2018, 07:49 PM   #162
jackjewell93
ECU: Emerald
It was over 40kg out and was always better with a passenger in it so I thought to my self something is up with corner weights will find out when I next drive it
Old 04-11-2018, 01:17 AM   #163
I'm all ears jack , and I'm trying to click ! So if you put it right to compensate for lack of a 10 stone passenger , what happens when the missing passenger gets in the car ,, after you have replaced them ?
Old 04-11-2018, 11:47 AM   #164
jackjewell93
ECU: Emerald
As it currently was without a passenger full throttle was nearly impossible with a passenger it was noticeably better, also the track day I did at castle Combe it was say going around a left hand corner better than a right it might of been the other way canít remeber the tracking castor and camber was set up the only thing that wasnít was corner weighting your probably correct when it comes to adding a passenger the corner weight was a waste of time but it was no fun driving with out a passenger as it was near enough impossible to drive full chat
Old 04-11-2018, 02:00 PM   #165
Well put jack! I get it , let's see what happens then!
How are you ajusting the weights ?
