Old 17-01-2017, 03:12 PM   #16
gav
ECU: Emerald
Can you scan parts or would they need designing on CAD?
gav is offline   Reply With Quote
Old 17-01-2017, 03:16 PM   #17
mic
Send a message via MSN to mic
Some machines have a built in scanner, mine doesn't so personally no. But if you want to buy me a scanner for about £300 I'll scan and print stuff for you
mic is offline   Reply With Quote
Old 17-01-2017, 03:59 PM   #18
gav
ECU: Emerald
Is a heat plate needed, I had a quick look at this https://www.amazon.co.uk/Flashforge®...ct_top?ie=UTF8 has rave reviews but no heat plate so guessing not needed.
Old 17-01-2017, 04:14 PM   #19
mic
mine doesnt have a heated plate, larger items are more likely to warp without as it cools quicker
maplin might have some on display if you want to see one before buying
Old 17-01-2017, 04:21 PM   #20
gav
ECU: Emerald
Just noticed that one doesn't do abs plastic which is recommended for car stuff anyway. Thanks for the help.
Old 17-01-2017, 04:32 PM   #21
mic
this looks awesome on youtube
http://www.ebay.co.uk/itm/XYZ-Printi...4AAOSwzaJYBNGv
Old 14-02-2017, 09:19 AM   #22
Eng
ECU: MEMS 2
I can draw up parts on CAD if anyone needs it.
How is the 3D printer going?
It took me a while to set mine up properly but it prints ok now. I've got a hictop aluminium extrusion prusa i3 but it's now been modified so that it can print better quality bits.
ABS plastic is tricky to get the settings right on as it likes to warp alot. Takes abit of trail and error and you definitely need a heated bed.
Eng is offline   Reply With Quote
Old 16-02-2017, 11:39 AM   #23
mic
I'm having extruder feed issues, looks like I'll just order a part in payday.
I have loads of ideas for cad stuff but I'm pineapple.
To get around a heated bed I do the largest skirt I can fit, sometimes for larger objects I'll use more supports than have a large surface on the bed. It's all trial and error really when printing something new
Old 16-02-2017, 11:40 AM   #24
had a brand new mini wiring loom turn up the other day for my restoration , and the plug that goes into the back of the dials/dash looks to be 3d printed ( its a funny plug , not std i am sure )
#justsaying
Old 16-02-2017, 11:50 AM   #25
tag141
Which extruder are you using.
www.16sth.com
tag141 is offline   Reply With Quote
Old 16-02-2017, 01:18 PM   #26
mic
This part. The bearing doesn't spin so the feed isn't continuos. I've changed the bolt and stuff and nothing seems to be great. Only a tenner for a new one
Old 17-02-2017, 01:18 PM   #27
tag141
I see. I have a plastic one. Filament wouldn't feed as there was no tension between bearing and drive gear and no means of adjustment. Ended up putting a shim underneath the spring,
www.16sth.com
