Old 07-09-2018, 08:16 PM   #61
twincamtone
twincamtone's Avatar
ECU: Standard MEMS3
Getting stuck in to the wiring
Old 08-09-2018, 01:51 AM   #62
Thers some amazing men on this club!! Far stretching , yourkshire , Cornwall USA, Australia, urope, semi French isles
All over everywhere , Devon's excluded somehow,
Old 08-09-2018, 07:45 AM   #63
Lancashire?!
Old 08-09-2018, 11:37 AM   #64
twincamtone
ECU: Standard MEMS3
Don't put Cornwall there yet...The electrics are confusing the hell out me
Old 08-09-2018, 04:41 PM   #65
I realized when I started I wouldn't have enough room
Old 11-09-2018, 05:51 PM   #66
twincamtone
ECU: Standard MEMS3
Finished the exhaust manifold and thought it would be a good idea to wrap it as it's going to be about 1/2" from the front grille. Got the front pipe on too, just need to sort the rest of the exhaust now.
Old 28-01-2019, 05:40 PM   #67
twincamtone
ECU: Standard MEMS3
It's been a while since the last up date, so here's what I've been doing, apart from freezing me nuts off out in the garage.
The plan is to build a new dashboard that will house the MG F, ZR speedo etc and then make moulds of all the sections.
I decided to trash the old dash I made a few years back and use parts of it to make the basic shape for the new one, plus a bit of roof guttering, cardboard and loads of packing tape to hold it all together
Here's the old dash
and here's all the bits taped together
Then covered it in fibreglass matting
Test fit
Then covered it in loads filler
Filler sanded down and another test fit...just to be sure.
The speedo surround was next.
Now I need to design a centre section to hold four 52mm gauges, MG switches and heater controls and if there’s room, a master cut-out switch.
Any suggestions welcome
Old 28-01-2019, 08:15 PM   #68
If you want a bit of bling then what about using the Rover BRM heater controls? They’re a turned aluminium finish and look quite nice compared the black plastic.
Old 29-01-2019, 12:20 PM   #69
twincamtone
ECU: Standard MEMS3
I like the sound of aluminium, but I'm not keen on the star shape design, would be better than plastic though.
