#1 |
ECU: Motronic 2.8
Like a plum I put my engine in before fitting the oil pressure sender and now it's up and running access is rather limited, any suggestions? Best option I can see is removing the driveshaft?
#2 |
Really? I thought mine sat above the driveshaft. I think you should be able to do it with the driveshaft in place. Oh maybe if you have the split shaft arrangement it takes up more room...
Whale Oil Beef Hooked! (use Irish accent) |
#3 |
ECU: Tweaked DTA
bit of a faff but you should be able to get it without removing anythng
To insanity & beyond!! Geoff |
Thread Tools | |
Display Modes | |
