Old 10-08-2018, 10:49 AM   #1021
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
2 maybe looks a bit weak but might just be the camera not picking it up great. Really don't see any reason why this isn't at least coughing even if it's not starting.
Sent from my F8331 using Tapatalk
I've got 3 long studs in my hand.
NudgerSS is offline   Reply With Quote
Old 10-08-2018, 11:14 AM   #1022
Yes, it did start years ago , I'm now going to compression test it , just wish I had a shelf full of suspect parts to swap just like I did back in the mini days ,
Old 10-08-2018, 10:06 PM   #1023
Compression test , l nearly chopped my little finger off ,
https://youtu.be/zSOqsXzcFhw
Old 11-08-2018, 12:36 AM   #1024
Have to say Tracie looks impressed with the progress you are making mate.
Sammy had a similar look this week when I have just spent £400 on welding on Scorpion.
Old 11-08-2018, 08:12 AM   #1025
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Put it all back together then and it should fire up. Hey presto.
Sent from my iPad using Tapatalk
Old 11-08-2018, 11:22 AM   #1026
Yes Andrew, they just don't get it do they! How do they know as well lol,
Nice vote of confidence johnner, but nothing,s changed lol
I just rechecked what I allready knew! Like we do in times like this, it's not going to start, thinking on "again" I read a thing somewhere about the black live for coilpack should also come from altinator charge line, I'm not used to this stuff, thought recollection is making me think the sparks are to large and not sounding cracky enough ,or to open and blue, so can't afford a replacement coil so I need to take a look at that,
Old 11-08-2018, 11:31 AM   #1027
Does the coil have a little box with it? Should be an amplifier, the plug on the dizzy should plug into it.
Old 11-08-2018, 11:52 AM   #1028
Good point, yes it dose I found a image on eBay of same kit and did check, .mine is tucked away under main heat sink ,
Thing is,,there is spark , but the active mind starts to qwestion, I even wonderd if the wire I used to go to coil is not correct ect ect , even doubting the spark plugs lol
Old 11-08-2018, 01:02 PM   #1029
I would say because you have a spark that thereís nothing wrong with your coil, if you turkey believe the spark is weak then I would question that amplifier.
I still believe the issue lies else where though due to it not even trying to fire, but Iíve been wrong plenty of times before!
Old 11-08-2018, 03:40 PM   #1030
Yes I do , no choice ,I will pull it and take a look , not that it will change out, but thinking on I don't trust the look of spark I'm up north next week so that may give me a brake,
Old 13-08-2018, 09:20 AM   #1031
wee man
wee man's Avatar
You selling up???
12.71@108.44
wee man is offline   Reply With Quote
Old 13-08-2018, 09:54 AM   #1032
Originally Posted by wee man View Post
You selling up???
Maybe trying , won't make much I don't think, keeping the mini got other plans for it, still involves 16valves and 5 speed lol
Old 13-08-2018, 09:59 AM   #1033
wee man
wee man's Avatar
Wouldn't it be cheaper to buy new dizzy set up tested from h and h ignition solutions or send your kit for them to test. Strip bike carbs give em a service. Hey presto its running for you. Or bin the bike carbs and go 45s or throttle bodies. If you go anythin else its gonna cost just as much. Dont think there is a cheap conversion these days. 1.6se was always a cheap route but rare now.
12.71@108.44
Old 13-08-2018, 10:00 AM   #1034
wee man
wee man's Avatar
Should list it all seperate tbh. Not complete.
12.71@108.44
Old 13-08-2018, 10:54 AM   #1035
NudgerSS
NudgerSS's Avatar
ECU: MBE 967EF
Saw this and thought of you Shaun
