#1 |
Hey guys time i started a build thread on here...
Before i start and give you the brief for this i would like to make you aware that this is more of a "scrap heap challenge" using off cuts and re-cycling as much of the cars as possible, so where as most people would buy nice correct metal, we are using either what we have, found in a scrappys or what was already fitted to the cars. So here we go: Aims: To build and compete in the PPC £999 Challenge Complete a sub 10minute lap of the ring SRR09 Budget: £999 or under Car: Classic Mini FREE Toyota Mk1 Mr2 FREE Plan: To build a classic mini complete with toyota running gear Target Bhp: 150 Heres the build: Date: 22/12/2008 Money Spent £0 Time: 20.00-1am Work Done 1. Steam cleaned MR2 2. Brought in MR2 and removed engine and running gear 20-15 Toyota nearly Clean 21-20 Engine nearly out (honest) 00.59 (its out at last!) http://www.staffsminis.co.uk/images/..._P231208_00.59[01].jpg Hands on Dazzler Fartinmartin Dangermouse (evening teaboy) Date: 29-30/12/2008 Money Spent £-30 Scrapman gave me £30 for the MR2 Time: 2 days in and around other jobs (5 hours total) Work Done 1. Stripped all other bits of MR2 2. Tidied Back room out 3. Moved MR2 out 4. Moved mini in 5. Got MR2 Collected working on the MR2 (29/12/08 12.30) http://www.staffsminis.co.uk/images/..._P291208_12.30[01].jpg Workshop tidy and engine in place ready to play(29/12/0 Bye Bye MR2 http://www.staffsminis.co.uk/images/..._P301208_12.37[02].jpg Hands on Dazzler Red5 jnr update Just sat the body over the engine to see what room there is... Subframe building tomorrow! http://www.staffsminis.co.uk/images/..._P301208_18.00[01].jpg Date: 03/01/09 Work Done Cut down subframe to check for clearances and get a general feel for position Time 5 hours 12.41 17.02 It looks from the pics like nothing has been done, however lots of progress today, got the engine in the position where it is going to sit with suspension towers in place (std mini front cones etc), gearbox clears, pulleys clear, drive shafts will clear and fit so... Monday we will make the first mounts to hold the engine to the towers which are fitted. For a round nose this is going need custom inlet manifold and exhaust as first thought, but for clubman the std exhaust will fit with enough room for a front mounted rad. Date 10-11/01/09 Money Spent £0 Project total £-30 Time: 13hours over 2 days Work Done Made front subframe mk1, fitted all suspension componants, fitted to car, placed on wheels to check for clearances. Sounds like not a lot, but honest, its loads of work! http://www.staffsminis.co.uk/images/..._P100109_16.41[01].jpg Just checking, it looked good Its in and on its wheels! http://www.staffsminis.co.uk/images/..._P110109_21.30[01].jpg Hands on Dazzler FATLAD Date: 23/02/2009 Time Spent: 19.30-22.30 Money Spent: £0 Total Money: - £30 Hands on: Dazzler & FartinMartin Work Done: So tonight we have really kicked back in, we started by making a mock up Exhuast Manifold out of toilet paper tubes, we then did something similar to the inlet to give us an idea of space etc. We have modified the Oil Filer housing and removed the oil cooler plate We then moved onto the Gear linkage, which i am please to tell you that from draft we have completed, all we have left to make is two cable holders which we will prob do on the car! I only have a couple of pics which are not worth showing, however when the linkages are complete with cables i will get them up Date: 01/03/2009 Time Spent: 11.00-18.00 today 1hour Yesterday Money Spent: £3.90 Total Money: - £26.10 Hands on: Dazzler & FATLAD Work Done: Lots of bits so... heres the story starts yesterday Well yesterday was soooooo funny we went down to the local scrappers for some tube to make the inlet from, found what we wanted went to the guy in the yellow coat Daz "how much for this" Man "whats it worth to you" Daz "dunno maybe a tenner" Man " dont be silly give me a fiver" Daz " ok i will get me wallet, can i throw it in the van" Man " quick get it in the van, quickly" Daz (puts hand in pocket pulls out £3.90) "I have 4quid in change" Man "quick give us the money and grapes off, the owner is coming" LOL, looks like we have paid some random £3.90 for some gear from the scrappy we laughed all the way home! Next up we have been using that steel and random pipes to make the inlet manifold heres to pics, its not finished yet http://www.staffsminis.co.uk/images/..._P010309_13.12[01].jpg http://www.staffsminis.co.uk/images/..._P010309_15.20[02].jpg jnr update Had ten mins on it tonight, i think you get the idea how its shaping up, i will have it finished for the weekend! Ok then two Updates Sat & Sunday Subframe time spent: 12hours over two days Cost: £0 Workers: Dazzler & Bleet Removed subframe, added tie bars and strengthening also finished off the mounting point on the Gearbox side, the only thing left to do on the frame now is rear engine mount & Alternator bracket. Also added front bar http://www.staffsminis.co.uk/images/..._P150309_14.34[01].jpg Update 2 Tonight Inlet work: Time spent 2hours Workers: Dazzler Cost £0 Total Cost £-26.10 Tonight i have made more progress on the inlet tomorrow i will be porting it smooth and then placing the ends on
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. cleaning equipment and chemicals for your mini! Last edited by Dazzler; 14-07-2009 at 07:17 PM. Reason: Changed title |
#2 |
Make: Toyota
ECU: Megasquirt 1 V3 + Ford EDIS
That frame is somewhat dissimilar to mine Daz:-
All that we know, is hate and machinery. We're engineers. |
#3 | |
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. cleaning equipment and chemicals for your mini! |
#4 |
ECU: Mems
So what are you going to spend the £999 on
Good progress keep the pictures coming.
13.5 @ 101mph standard VVC engine Rover no show and all go!!!!! |
#5 |
ECU: Tweaked DTA
Impresive....subframe looks workable with the side/top bracing welded, keep up the good work, look forward to seeing your next update
#6 |
ECU: GM
daz have already spent the money on tools lol
terry
terryg RWD mid engine 2L vauxhall mini conversions lol |
#7 |
Ok, this is a partial update the rest will come in a propper write up sometime sunday i would think with pictures and stuff
We have fitted the engine and frame back into the car and have found we need to mod the sump as it fouls the tie bar, we though the gearbox was going to catch however a quick tester with me jumping up and down on it, i am a full 18stone gave us full travel and has had the floor touching the gorund without and further probs Will take some pics of the sump later we are just about to start if for the night shift!
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. cleaning equipment and chemicals for your mini! Last edited by Dazzler; 02-10-2009 at 03:50 PM. |
#8 |
Update time...
So there has been lots and lots done, too much to list in my usual way, heres the shorts i was -£26.10 I have spent: £230 (front end, roof, boot) NOW CLUBMAN 2 PART FRONT £15 metal for boot floor and tubbing So thats £245.00, less the £26.10 (gonna call that 25 for ease) So i am at £220 spent Other updates, i have been given by Ives a fuel tank from a tigra complete with fuel pump, the scooby bax box is out and out of the exhaust shops "free" second hand stuff i have had a "Astra GTE back box" So heres the pics This is where i was upto, frame in the car back on its wheels roof cut out ready for fibre roof skin ![]() heres the Inlet test ![]() ![]() Then the front was cut off to make life a whole load easier while making stuff heres the home for the alternator ![]() The sump fouled the Tie bar, so thats been cut and modded ![]() The inlet was taken closer to finishing ![]() ![]() ![]() Ok, so this weekend lots done and focused on getting the body ready-er for MOT lol free stuff is how it started ![]() Then a big hole was cut ![]() Then the flat floor went in ![]() Then the exhaust was fitted for maximum ground clearance ![]() So, the arches are tubbed the back end is low and 90% done the only big choice i have now is do i fit the bumpers or de-seam it on the back?
#9 |
ECU: Mems
Your flying with this conversion keep the good work up.
I would have to say de seam the back. Smooth bum
#10 |
Loving this! What do you reckon this whole project is gonna come in at? (obvs under £999).
I'm with Matt, gotta go for the smooth rear end
What have I done this time... |
#11 |
cheers, well i am a little pushed for time to do a propper de-seam on the rear but will see
A lot will depend on how much i spend on "bling" i think its going to be around 500-600 by the time i have a digi dash, bucket and harness will see! Tonights update I have been busy getting the shell ready for MOT so i have rolled the shell on its side to make it easyer, i have done repair work to the whole side of the car, finished the tubbing and the underside of the boot floor Here it is ![]() and another view before i start on, showing exhaust position ![]() after several hours its now welded then seam sealed ready to do the other side tomorrow before clean and paint ![]() Martin has been busy sorting out the loom on the engine which is complete in the frame on a pallet oh i fogot a tenner needs to go on the budget for the rear valance
#12 |
Right then tonights update
Rolled it on its other side and sorted that out heres the before and after ![]() ![]() ![]() Then a quick blanker was made for the fuel neck hole ![]() ![]() The boot has now been completely finished and is seam sealed ready to go ![]() So tomorrow will be working on the front of the shell i am still hoping to have this painted for the weekend then the build up can begin.
#13 |
I forgot to add this, for those that are wondering why i made a custom inlet
heres the std one in position
#14 |
Update time:
Last night, still welding the shell, its a total shed! no pics as i was too busy, i would say i am 75% done welding the shell, this should be finished tomorrow.... I have taken tonight off welding its starting to bother me, so me and mart have turn our attention to the wiring ![]() Had about 2 hours at it, we have go the ecu system working and starter etc so we are happy that we can make it run using the toyota fuse box, so we will be bringing the mini loom to the toyota fuse box and it will go from there Jobs left to do Drive Shafts (materials here monday) Finish Shell welding Build up for MOT Fit roll cage Paint shell Wire up Sort out cooling system Exactly 1 month to go until the event!
#15 |
Make: Toyota
Daz,
Mr2 wiring diags here: http://opc.mr2oc.com/ Go about half way down the page under "electrical" - not the bgb stuff.
| Thread Tools | |
| Display Modes | |
