#1 |
hi guys thought i might get a few pics of my mini up
also a few pics of the engine i have also been making a subframe post up some pics of the frame soon[img] [/img][img] [/img][img]![]() [/img] [img] [/img]here's a couple of pics when i first got the mini ![]() ![]() ![]()
Think Twice Before Passing This Mini.....It Could Make U Look F**k**g Silly..... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Last edited by cooper_mark; 22-06-2010 at 11:43 AM. Reason: front is now fitted |
#2 |
a couple of shots of my subframe so far hopefully start chopping the old frame out in the next couple of days need some more welding wire
![]() [/img]
Think Twice Before Passing This Mini.....It Could Make U Look F**k**g Silly..... To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
made alittle more progress on my frame today
just some cutting out to do and tidying up on the frame ![]()
#4 | |
CC: 1500
ECU: Points dear...remember them??
Just call me 'Daisy' ;) Allow Smilies No Can Upload Images for Signature No Can Upload Animated GIF for Signature No BAH HUMBUG! |
#5 |
it was attacked by some 1 with a baseball bat
#6 |
Subframes looking good, think i'll start mine the same way, adding tube and cutting the original away after instead of making a frame to hold the mounting points. Good work.
Are you keeping it the same colour? one of my favorites |
#7 |
yeh will be keeping the colour cas i love the volcano orange thats 1 of the reasons i had it
#8 |
just a small update
managed to get most of the old frame chopped out couldn't believe how long it took here's a few pics ![]() ![]() ![]() ![]() if any one can see if i am going wrong anywhere PLZ post comment's
#9 |
Looking good so far, but will add, you may need to cut and move the lower suspension pin front mountings back. If doing this you will need to cut the "wavy" bit out of the bottom pin and weld it back together.
This is the only pic I can find, haven't got any of the frame mod, but you should be able to work out what I mean. EDIT: here's a pic of the actual pin (one of) after it had been modified...
What have I done this time... |
#10 |
youll have no ground clerance with that frame, itll probably bottom out if you get down to the bump stops! get measuring against a normal mini
11.9@118 :) Denis. |
#11 |
ECU: Mems
You might get away with it but you wont be able to lower the car. Plus a vauxhall is very heavy so you will need some very hard suspesion to keep it of the ground.
13.5 @ 101mph standard VVC engine Rover no show and all go!!!!! |
#12 | |
![]() these are the pins you mentioned owen
#13 | |
i have tryed to build the frame around the original frame so i'll see what happens
#14 | |
i proberly will be looking into coilovers
#15 | |
Yup they're the boys. You'll see what I mean as the bit you need to move back sits right where the driveshaft wants to come out (on both sides).
| Thread Tools | |
| Display Modes | |
