Old 07-03-2008, 05:29 PM   #1
Travoli
Default Travoli's B18C Standard Round Nose Conversion
Thought I had enough pictures to start to finally start a thread. This project has been in the works for a long time, and is now finally physically coming together.
The setup:
-MKIV Style Mini
-All custom Honda B18C with S80 LSD (Type R) Transmission
-Allspeed subframe
-Standard length round nose, original steel fenders
Extras:
-Jack Knight electric power steering column
-RH Gas tank
The most important lessons thus far:
1. It's a lot cheaper and easier to start with a Honda front clip. Motor mounts, half shafts, starters, sensors, wiring harnesses, etc.. start to add costs quick.
2. There is a lot of custom work to be done, and even the best planning will still leave issues to be worked out on a custom setup.
The motor, from Inline Pro http://www.inlinepro.com/
The Jack Knight power steering column
New Fuel Pump
Fitting the RH gas tank
HASport.com motor mount 1
HASport.com motor mount 2
Motor in the Allspeed subframe
Half Shaft is hitting the rear mount, need to adjust it.
That's where we are. I'll post more soon.[img][/img][img][/img]
Travoli is offline   Reply With Quote
Old 07-03-2008, 06:32 PM   #2
matt 1380
matt 1380's Avatar
CC: 1595cc
Looks very good!
My Build Pics at: http://s143.photobucket.com/albums/r...jjd/?start=all
matt 1380 is offline   Reply With Quote
Old 07-03-2008, 06:32 PM   #3
jiminwatford
looking really good
whereabouts are you? America?
jiminwatford is offline   Reply With Quote
Old 07-03-2008, 07:55 PM   #4
Travoli
Yes USA.
Old 07-03-2008, 10:37 PM   #5
Quadra
Quadra's Avatar
What type of inlet are you using, or is it custom built.
Quadra is offline   Reply With Quote
Old 07-03-2008, 11:37 PM   #6
Travoli
Golden Eagle Intake Manifold
http://www.goldeneaglemfg.com/race_intakeman.html
It is large but makes a lot of power. We still have not had a chance to fit the subframe into the car yet, and I know that this manifold will require modding of the firewall. I'm happy to do that, as long as it doesn't interfere with the dash on the inside. I won't be using a normal stereo setup due to this manifold.
If I need to, I can also have the runners cut and welded shorter. It shoudl still look clean as they are basically tubes instead of a cast piece. But it will produce less power.
I considered a JG Edelbrock manifold which is 1 inch shorter than OEM and would help with the firewall problem, but Inline Pro (motor builders) said the Golden Eagle will produce much more power. I want to give it a shot at fitting in the car.
JG pic:
http://www.modacar.com/Merchant2/int...g_manifold.jpg
Old 07-03-2008, 11:45 PM   #7
Travoli
The Rear subframe mount was slightly modified to fit the half shaft. Hopefully the steering rack fitment won't be affected. The axles are in!
Old 08-03-2008, 01:42 AM   #8
texas mini
Send a message via ICQ to texas mini
Very nice build.
Which state are you in?
texas mini is offline   Reply With Quote
Old 08-03-2008, 03:27 AM   #9
Travoli
VA but the car is being built in IN. Tough to find good craftsman these days 700 mile drive is well worth it for this work though.
Old 10-03-2008, 10:11 PM   #10
Travoli
Cutting...
Old 11-03-2008, 10:14 PM   #11
Travoli
Motor test fit today:
You'll notice the Steve Alexander header. Still a tight fit all around, but a fit.
The cut bits:
Old 12-03-2008, 05:43 AM   #12
Latka
Wow... your car is comin' along great! I love how you just trimmed the inner fender instead of hacking the whole thing out. I'd like to keep the front end also (without going to a removable one I mean).
Definitely following your progress!
Latka is offline   Reply With Quote
Old 12-03-2008, 08:49 AM   #13
Mintegra
Mintegra's Avatar
ECU: JDM OBD2
Hi Mate,
Loving the build thus far.
Please could you tell me which exhaust manigold (header) you are using and driveshafts??... and what radiator your intenduing to use??..
Im currently on with the same build but have gone fibreglass flip front!..
Many thanks
Chris
Old 12-03-2008, 03:49 PM   #14
Travoli
Sure thing,
The exhaust manifold is a S. Alexander model. You can contact him at stevealexanders@netzero.net, or search for him on this forum.
Drive shafts are from Allspeed Engineering, with a brand new half shaft from Honda in the middle.
I'm not sure on the radiator yet. I need to ask MattG what he's used in the past. We are going to take measurements once the motor is sitting in its final spot and then either see what is availavle, or have something made custom. More on that as it develops.
Old 12-03-2008, 04:08 PM   #15
Mintegra
Mintegra's Avatar
ECU: JDM OBD2
Cool thanks for the info. Ive contacted S.Alexander before regarding Manifold but he never got back to me... Does it fit straight into the Allspeeds Frame??...
Cheers again
C
