Old 06-02-2012, 05:06 PM   #1
adamb
adamb's Avatar
Default VVC Pickup
So I finally picked it up, had no front wheels or Nothing, so first job was to attach hubs back to the arms and fit some wheels so I could move it off trailer lol.
Then off the trailer in the garage where all the work will take place
The plans are to drop a 1.8 vvc K series in , keep the roundnose solid but with a flip front and go for the sleeper look bar some wider arches
adamb is offline   Reply With Quote
Old 06-02-2012, 06:20 PM   #2
wilp99
wilp99's Avatar
CC: 1797
ECU: S300
nice.. looks like a great platform to begin with (fairly solid). did you get it on a good price?
Old 06-02-2012, 06:35 PM   #3
adamb
adamb's Avatar
Yeah, front is solid, rear and bed is solid, needs new rear arches both sides, some patching behind the a panels, new front end obv and new floors, sills and steps.
Other then that solid Haha
I already.have all the front panels,(2 front lower parts) 2 bonnets, windscreen, left hand floor, both sills both doors.
All the panels nearly that I.need. Didn't need an engine as its gonna be a k series
Got it all for 1270. Good price compared to some of the others around.panels worth couple hundred so.
Old 16-02-2012, 09:50 AM   #4
adamb
adamb's Avatar
Some more progress, pulled the passenger side step, and floor out as they were new panels with tacks on! The floor was held in place with 6 tacks!.
Also removed the rear glass and loom, just the front subby to remove then I can get it on its side to do the underneath and floor properly.
So while removing the floor I found out the previous owner must of worked at a body filler company.
Next problem is they tried to deseam the front window,
any advice on what to do with this?
Project mini VVC pickup :)
Build diary
Originally Posted by Kam View Post
With a mini track it will be like Jordan - seriously top heavy!
Old 16-02-2012, 09:03 PM   #5
Kam
Kam's Avatar
That does look a very tidy one there for that price, good luck
Old 17-02-2012, 07:19 PM   #6
adamb
adamb's Avatar
Cheers, and as for the the window pillar, what would your advice be?
They gave tried to deseam it, welded it just hammered it in and fillered the whole thing :/
Bit of progress not a lot.
Got the front subframe off so I could put it on its side.
then removed the rear subby and petrol tank
heel board needs repairing another subframe mounts, 6 of the 8 have sheared off so sorting them.
Then I can put the floor In and attack the other side floor.
Build diary
Old 17-02-2012, 08:12 PM   #7
Kam
Kam's Avatar
Your asking me? no no, you can add bodywork to the many list of things I can't do!
Post it up in non 16v chat, not everyone will see it in your build diary
Old 17-02-2012, 08:50 PM   #8
minidaffy
minidaffy's Avatar
CC: 1500
ECU: canems
might not work but could you attach a slide hammer to the seam and work your way up the seam pulling it out bit by bit?? good quality mole grips welded to a slide hammer might do it?? then just grind the welds flat so a seam strip fits...
real good base for a pickup project there!! good find and good luck!!
bloody million dollar mini strikes again...my wallet hates my car.....
minidaffy is offline   Reply With Quote
Old 17-02-2012, 08:56 PM   #9
adamb
adamb's Avatar
Ah sorry kam
and that's a great Idea minidaffy, Il probs do that.
Build diary
Old 05-03-2012, 10:44 AM   #10
adamb
adamb's Avatar
right, so progress has been abit slow as i can only work it every now and then.
but got the passenger side floor in and tacked, need to finish the welding. Reparied the front behind the a-panel and the heel board.
will get some pics up when it is welded up.
then ready to do the other side of the floor
Slow but steady wins the race
Build diary
Old 07-03-2012, 12:25 PM   #11
bartman
bartman's Avatar
ECU: standard honda
awesome project i was hoping to do a mini pickup but they are getting hard to find now good luck with the build
bartman is offline   Reply With Quote
Old 07-03-2012, 12:32 PM   #12
adamb
adamb's Avatar
Cheers, this will be a long term keep car. Don't plan on getting rid of it lol
Build diary
Old 09-03-2012, 08:56 PM   #13
mclovin
CC: B16A6
ECU: Planning to use Dictator
Nice project dude
The only substance i abuse is 95 Unleaded
mclovin is offline   Reply With Quote
Old 09-03-2012, 09:41 PM   #14
adamb
adamb's Avatar
Thanks,
finally ordered a drivers side floor and 2 rear arches. I think that's all panels bought part from rear bulkhead. Just a pot of welding to do before I get an engine lol
Build diary
Old 23-03-2012, 11:09 PM   #15
asahartz
Bank of Dad here. Though I'm not paying for it all, I end up funding some of it... Like the "borrowed" paint etc...
Fortunately or unfortunately, Adam also lives next door to me. Unfortunately because my tools have a habit of disappearing into his garage, fortunately because I know where they are and can fetch them back again!
I'm also technical advisor, having done many Minis before. I have a Clubby Estate in the garage now that will be getting a Micra engine when I've sorted the bodywork (which is worse than Adam's pickup! - but it does at least have a front end).
Adam & I flipped the pickup over yesterday. Useful to have muscle available when you need it; he helped me flip the estate of course. The pickup is a lot lighter!
