Old 15-01-2012, 04:21 PM   #1
Keegan
Default Mini Thirty VTEC: Project Hugo
Howdy,
I've been planning this for a while and lurking until now but today I finally started working on my Mini VTEC build. Based on a 1990 Mini Thirty in black that has seen better days but looks to be structurally sound.
I've a B16A2 sat in a friends garage and I'm planning on using Watsons frames along with a DTA ECU. Today I started stipping out the interior so the project is now officially under way!
Wish me luck.
Keegan is offline   Reply With Quote
Old 15-01-2012, 05:17 PM   #2
jimmorris3
Send a message via MSN to jimmorris3
All I can say is its well worth it, keep the weight down and ull have a seriously quick motor, good luck bud
jimmorris3 is offline   Reply With Quote
Old 15-01-2012, 05:22 PM   #3
Keegan
Thanks Jim, I'm just looking forward to having a reliable and nippy engine to be honest. I've always wanted to do the Italian Job too so the VTEC should make light work of it.
Old 15-01-2012, 05:43 PM   #4
nice,, keep the half lether seets safe mr mouse likes them to eat,all be it for me to say but try not to go ripping it all to bits,i would do one job at a time and finnish it,good luck,shaun
Old 15-01-2012, 06:54 PM   #5
Keegan
Aye, I'm setting myself one job at a time to do so it doesn't seem too overwhelming. One thing I'm not sure of is the seats, tempted to keep them but not sure if I'll slip off them in the corners.
Do most people upgrade to buckets or will the standards do the trick?
Old 15-01-2012, 07:30 PM   #6
they used to make good money as a set with door cards, that may help with your build funds,shame tho,ive got sum carobie[cant spell it] seat covers in my mk1 ,thay have lumps built in to keep you in the seat,not sure if u can still get them,best of both worlds originalaty and put them on and your held for raceing,
Old 15-01-2012, 07:51 PM   #7
Keegan
Hmm, thanks for the tip as I hadn't thought about covers. I'll have a look around.
Old 22-01-2012, 04:06 PM   #8
Keegan
Finished removing the fluffy parts of the interior today, just the padded dashboad and heater to remove.
Despite it not having a head unit I've found no less than four speakers and a 10 CD changer, no wiring between them though. Odd but not as odd as the massive hole cut into the parcel shelf. I'm also pretty sure the rear seats should be held in place by more than two screws!
A friend is coming over to have a look at the rust in the week, hopefully nothing too surprising will be found.
Old 09-03-2012, 10:26 PM   #9
Keegan
A bit of a delay but the verdict is that the body work required is minimal, the worst appears to be a slight buckle where someone jacked up in the wrong place and a bit in the floorpan.
Apparently I've got a bloody good example of a well looked after car, I can't help but feel there is something lurking beneath I've not discovered yet though! Still, time to crack on.
Old 10-03-2012, 04:01 AM   #10
its a boutey,,
Old 10-03-2012, 05:16 AM   #11
MiniMike
CC: 1500
ECU: Honda standard p08
I have also done a VTEC Mini 30.. but Cherry Red one, and a D-series... looking forward to your updates.
http://www.16vminiclub.com/forums/showthread.php?t=7466
89 Mini 30...finished the car ... again!
MiniMike is offline   Reply With Quote
Old 10-03-2012, 09:02 AM   #12
MINIMAD30
ECU: STD honda
Non Vtec black mini 30 here =)
MINIMAD30 is offline   Reply With Quote
Old 10-03-2012, 10:16 AM   #13
Keegan
Thanks guys, I'll be sure to give your diaries a read.
Old 11-03-2012, 09:57 AM   #14
Kam
Kam's Avatar
That hole in the rear parcel shelf is very odd, maybe its for a passenger in the boot so they can stick there head out?
Have you got the watsons vtec builder dvd? very helpful if your not 100% comfy with what to do
Good to see another vtec
Old 11-03-2012, 07:31 PM   #15
Keegan
The hole seems to have been cut so that a 10 cd multichanger could be bolted to the parcel shelf, they may a right hash of it!
I do indeed have the Watson builders DVD, given to me by the man himself when I visited Watsons last year. I wasn't sure about how an extended front would look and Geoff let me go around and have a look at an example they had in at the time. Friendly fellow and very helpful with any questions.
