#1 |
Location: 1/2hr from FBM-Spec, 3/4hr if vauxhall powered
pair of blue sparco sprint seats with subframes to suit mini's. Drivers seat also fitted with double locking slider kit. Looking for £75 plus pp can adrop off in birmingham or bristol by arrangement
The grumpy bastaard!!! To some the glass is half empty, to others it's half full, being an engineer, to me the glass is twice as big as it should be!!!! |
#2 |
ECU: MBE
You got any pictures of these Mark? What condition are they in? Cheers
#3 |
They need a quick clean, and the drivers seat has some slight grind marks but other then that they are ok
#4 |
ECU: MBE
If you could get some pictures up that would be good.
#5 |
These are the seats and this is the worst one of the 2
![]() And these are the 3 small grind marks, the dark bits towards the back are just fluff ![]() But when i've just taken these pics i've found a small tear on the drivers seat that i hadnt noticed before, you cant really see it until you open it up with your finger. I know a lad who is an upholsterer so it may be possible for me to get it sewn up. ![]() ![]() obviously the harness is not included
The grumpy bastaard!!! To some the glass is half empty, to others it's half full, being an engineer, to me the glass is twice as big as it should be!!!! Last edited by Mark D; 05-12-2009 at 12:24 PM. |
#6 |
ECU: MBE
Thanks for the pics. Need something a little tidier tho. Cheers.
| Thread Tools | |
| Display Modes | |
