Old 16-08-2010, 11:53 AM   #151
VT-Doo
VT-Doo's Avatar
CC: 1797
ECU: Hondata S300
Would you mind posting up the pictures of the inner wheel arches that you cut?
By the looks of it you never removed the front end
Ian
VT-Doo is offline   Reply With Quote
Old 16-08-2010, 08:36 PM   #152
Travoli
VT-Doo, I wish I had more pictures inside the wheel wells, but I don't. There really isn't much left as you can kind of see in the other shots. I will ask Troy for a couple pictures and post as they come in.
For now, the custom Ron Davis radiator has arrived. Wow, looks great. Here's hoping the calculations are right and it cools the motor well.
Car is off to paint next week to fix several scratches and dings from having the motor replaced so many times.
My build Diary: http://www.16vminiclub.com/forums/showthread.php?t=6206
Travoli is offline   Reply With Quote
Old 17-08-2010, 01:40 AM   #153
Furyof4
ECU: Neptune FTW
Wow that rad is gorgeous!
Furyof4 is offline   Reply With Quote
Old 17-08-2010, 11:26 AM   #154
VT-Doo
VT-Doo's Avatar
CC: 1797
ECU: Hondata S300
Cool
That radiator looks
Travoli, was the front end removed at all?
Ian
Old 17-08-2010, 11:32 AM   #155
cables
cables's Avatar
CC: 1997
Send a message via MSN to cables
that radiator looks amazing, dare i ask how much?
If it aint broke......Your not driving hard enough!
cables is offline   Reply With Quote
Old 17-08-2010, 09:41 PM   #156
Travoli
Thanks guys.
VT-Doo - No, front was never removed completely.
cables - much cheaper in pounds sterling.
Old 18-08-2010, 01:10 PM   #157
cables
cables's Avatar
CC: 1997
how much then (pm me i am interested if the price is right)
Old 19-08-2010, 12:44 PM   #158
Mini fab
Mini fab's Avatar
ECU: PO8/ Chrome
Now let's put some a/c
5 speed is not an option!
Mini fab is offline   Reply With Quote
Old 20-08-2010, 12:12 AM   #159
Glenno
Glenno's Avatar
ECU: Honda
That's a work of art! Has it got an air bleed in the higher section of the rad?
Make sure you mount it in nice floating soft bushes of sorts - ally radators like to flex and give this design she might do unexpected things with some heat.....
Nioce!
www.eclipseengineering.co.nz
Glenno is offline   Reply With Quote
Old 24-08-2010, 08:12 PM   #160
danny_duke01
danny_duke01's Avatar
CC: D16A
Great build,good job!!
danny_duke01 is offline   Reply With Quote
Old 25-08-2010, 09:23 PM   #161
Travoli
Mini Fab - I purchased an A/C kit but I think that is getting a bit rediculous. Ironic, huh?
Glenno - thanks. Not sure about the air bleed. Definitely mounting it for flexibility.
A couple shots from today:
Old 25-08-2010, 11:23 PM   #162
Mini fab
Mini fab's Avatar
ECU: PO8/ Chrome
Well man just to humor you on your new acquisition , That rad looks very cool, with or without an a/c I believe that will work!
Old 04-09-2010, 09:15 PM   #163
Travoli
Got some pictures of the new alternator bracket today. I'm told that there isn't any chance of the alternator sagging with this thick piece.
Old 05-09-2010, 11:41 AM   #164
Hario'
Hario''s Avatar
CC: Zero
ECU: Stock Honda
*That radiator is bad ass!
*I think increasing caster angle can reduce effects of torque steer to a degree (no pun intended)
*There is no way to remove the air from the top 3 inches of your radiator ?!?!
Hario' is offline   Reply With Quote
Old 09-09-2010, 04:07 AM   #165
Travoli
All shiny again:
Next up: Pedal placement redesign.
