Old 23-04-2018, 07:52 AM   #1
Im not normal
CC: 998
Make: Toyota
Default Help with servicing Swift engine
Help needed.....
I want to service my 2003 swift 998cc
Has it got points....
I've purchased as follows leads,plugs,cap,rotor arm but wasn't sure of points .. This is where I need assistants what type are they if there is any,
Also it 10/40w oil ok to use
And what's the timing mark for setting the points .... Is it top dead center just before or after, I'm not sure that's why I'm needed some help,
Thanks ........
Im not normal is offline   Reply With Quote
Old 23-04-2018, 05:54 PM   #2
G10 especially 2003 won't have a point.
You will need to get timing light and connect to no1 cylinder with power from your battery.
Then start engine, shine your timing light to your crankshaft poulley which has groove for the timing. I think timing is 8 degreesbefore TDC.
Old 24-04-2018, 07:45 AM   #3
Thread split from Useful Suzuki Link thread
Build Thread - Standard Round Nose with K series subframe build begun
