Old 30-03-2018, 08:05 PM   #631
Nice alloys.
I got same one needs refurb. Just in case I want to go back to 10".
Good Luck!
Old 31-03-2018, 02:56 PM   #632
Originally Posted by Purtsi View Post
It'll pass the sounds great test with ease
Did you go through a similar registration in Finland?
Old 31-03-2018, 03:47 PM   #633
Well, we don't have a possibility to get highly modified cars on the road because if 50% or more parts have changed, the car will be classified as a new car which then means you have to pay the taxes of the new car + you have to get through all sorts of tests which are very expensive. I have not heard anyone to go through that.
So what we do then? We keep the changed parts to minimum (or don't tell about them at mot). We get dyno sheets that show that the power increase isn't more than 25% etc..
And then there are some cars on the road with +900hp with heavy modifications. Don't ask me how it's done, friendly mot tester maybe...
Old 31-03-2018, 04:26 PM   #634
Ok, sounds not that easy Swedish system is actually very good, you get a personal sfro Guy that does the scrutinering and helping you out with solutions to get the car on the road
Old 31-03-2018, 04:31 PM   #635
Well my Monaco’s got under the cage, not allowed on the street... I had these grp gt-seats that kind of curves forward at the head and clears the cage and yet maintaining a good driving position easier than moving the cage, they are super light as a bonus!
Old 31-03-2018, 04:32 PM   #636
Yeah. You have a different approach there as you're given solutions, we're given problems.
Old 31-03-2018, 04:35 PM   #637
Can you buy a modified car in Sweden and bring to Finland by any chance?
Old 31-03-2018, 09:13 PM   #638
I think it depends on if the car is registered as what it came from the factory or if it's self-built from the ground up which most likely will be a no-no. Also if it's from '77 or older it helps as before that you don't need to have the emissions test and from '94 onwards it's even more strict.
Anyhow, if I remember correctly there's one Pimlico Mini in Finland that can't be put on the road because it's not 'mini enough' or some sort.
Old 02-04-2018, 09:23 PM   #639
Seats in, let the torture begin, race coils...bye bye pelvis
Old 04-04-2018, 09:20 PM   #640
Some more work Done, bracing up the steering column, now its rock solid
Old 05-04-2018, 06:25 PM   #641
Snap off, Swedish made concentric = no play
Old 10-04-2018, 07:34 PM   #642
dirty tricks switches
