Old 27-06-2007, 06:46 PM   #61
crazykamper
Send a message via AIM to crazykamper Send a message via MSN to crazykamper
ive been also thinkin very much into this build..... the more info the better.... can you also post up on how you did the tail lights ect?? im trying to get as MUCH info as possible before i jump the train..... and pictures always help lots too! haha,
if i do a build, it will probably be with the older d16a6 as crx's are a little cheaper to come across.... thanks again!
crazykamper is offline   Reply With Quote
Old 04-07-2007, 11:36 PM   #62
tango
Originally Posted by allminicoopers
My Honda Engine and trans weight 325 pounds
I think the A-series engine/tranny complete with motor mounts, starter, alternator, manifolds and carburetor weights about 350lbs. I believe your 325 lbs were without starter and alternator. But boy they are almost the same weight!
Come to think of it, with Alu radiator, and fibre glass front, a Mini with Honda D series engine may even end up having same or better weight distribution.
tango is offline   Reply With Quote
Old 05-07-2007, 12:15 PM   #63
Joey.S
ECU: dta
[quote=Hoser]
Originally Posted by "Joey.S
Why not use your stock mini tank put a return line on it and run a MSD external F.I pump. $130.00can$ It works well for me.
Joe[/quote
I would rather not weld onto the tank, and avoid explosions or severe burns. But this is probably the way i will go, just with a Canadian Tire replacement fuel pump. El Cheapo!
CT does not sell a externel F.I pump. You don't have to weld on the tank just remove the float assembly and plum your return line on the round piece that fits in the tank, it works great for me and have the twin mini tank set up.
Joe
Joey.S is offline   Reply With Quote
Old 05-07-2007, 12:35 PM   #64
Hoser
Subframe: MTB
ECU: OBDII
Got a picture of that return setup? I think I know what you're talking about, but would like to see it.
Thanks,
Dave
72 Mini 1000 - D16Y7 swap in progress
Hoser is offline   Reply With Quote
Old 12-07-2007, 04:41 PM   #65
charliemurfie
I'm stuffing a D16A6 into a 1979 mini van. just got everything to fit up underneath the sheet metal last nite (after converting from RHD to LHD).
have my Southwest Speed reverse hanging pedal assembly on order as well as OBX intake and exhaust manifolds. Fiberglass front end is on it's way. I've also got the MTB hinge setup from gbcarparts.com on it's way as well. We're hoping to have it done and driving by the end of August.
Also, I just purchased an External Generic Fuel pump from CT @ $115, they do exist afterall!! just need to run a fuel pressure regulator with it and voila!
charliemurfie is offline   Reply With Quote
Old 12-07-2007, 05:15 PM   #66
Hoser
Subframe: MTB
ECU: OBDII
Wow! I'd love to see some pictures of the install Charlie! Sounds fantastical!
Old 12-07-2007, 06:26 PM   #67
strudel
strudel's Avatar
charliemurfie,
Please put me on your list for pics or post them here. My 61 van and D16A1 build has been on hold for too long and I need to get back into it . A few daily driver issues to complete first. Big difference in build will be that I am using the Honda complete front suspension.
By the way, what part of the country are you in as it's not on the profile. Helps if you add that in. JS
Austin Mini Van with DOHC Honda HP
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Honda reliability and power combined with Mini cachet and style.
strudel is offline   Reply With Quote
Old 24-07-2007, 09:07 PM   #68
crazykamper
^ i would love to see more of the suspension and the engine how you said you would build it.... very interested... as i was thinking the same thing...
anybody got any pictures of the taillight harness etc.... im still curious, haha
Old 25-07-2007, 12:20 AM   #69
strudel
strudel's Avatar
crazykamper,
You might want to look at the last 6-7 pictures on this page to give you a bit of an insight into what I did. The project got stagnated and I hope to resume it this year. It is just too easy to get side tracked with other stuff. It's time to focus in and start up again.
http://www.angelfire.com/droid/strud...ics4/sfg4.html
I may not continue this particular web page as HTML just is too horlicksbersome to work in on a part time basis. JS
Old 25-07-2007, 12:08 PM   #70
Hoser
Subframe: MTB
ECU: OBDII
Sorry, still no pictures of my minute progress. I just took the bulb sockets out of the Mini tails and modified the stock Honda sockets to fit. A little silicone and away we go!
Old 03-02-2010, 04:45 AM   #71
allminicoopers
ECU: Standard original honda ecu
Hello everyone i finally finished my mini i will post pictures soon
on pogress vtec D16Y8 honda del sol
building my own frame
allminicoopers is offline   Reply With Quote
Old 03-02-2010, 05:11 AM   #72
allminicoopers
Here is my first drive with no problems coming back from the aligment shop with new tires im so happy alot of power
here its a video
http://m.youtube.com/#/watch?desktop...ey3JhzcU&gl=US
Old 08-02-2010, 03:36 PM   #73
Hoser
Subframe: MTB
ECU: OBDII
Alright, so I pulled the trigger and bought the Minitec MTD kit.
I should have it in a week or so.
I'm reading up on current builds and problems.
Maybe we should get a sticky for Minitec problems and suggestions?
Old 09-02-2010, 12:16 AM   #74
Freebies
Freebies's Avatar
Subframe: MTB
CC: D15B
ECU: MTD Frame, not MTB
congradulation on your purchase...
I have the same kit. Very well made, good quality. Their only problem is the service. Other then that, i' satisfied with my frame.
For the intake, i did cut mine and reweld it at an angle. Fits like a charme. Look at my build diary to get some pics. I've cut a Skunk 2.
By the way, are you in any local club ? I'm from Mainly Minis Montreal...
Have fun with the built!
Freebies is offline   Reply With Quote
Powered by vBulletin® Version 3.8.3
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
